- If your identity tool only sees apps behind your SSO, it's missing your fastest-growing attack surface. The free SaaS and AI tools your employees are signing up for with corporate or personal emails are invisible to SSO and increasingly where breaches start.
- For lean IT teams, deployment complexity is a security risk in itself. An identity security tool that requires dedicated engineers to deploy and maintain means SaaS visibility never gets turned on.
- Your organization has days to close the gaps an AI exploit might reach. The right tool is the one your team can easily deploy and run this week, not next quarter.
- Shadow SaaS and AI visibility is now a critical part of identity security. The April 2026 Vercel breach traced back to a third-party AI tool that IT didn't know existed. Shadow SaaS and AI are being actively exploited right now.
- Identity security without SaaS visibility leaves half the attack chain open. Both controls are needed to limit blast radius after an exploit succeeds.
- Speed matters when the attack surface is growing daily. LastPass SaaS Monitoring delivers immediate SaaS visibility, and SaaS Protect turns it into enforceable controls.
AI models like Mythos haven't changed the fundamental goals of attackers. Stolen credentials, lateral movement, and data exfiltration remain the playbook. What has changed is operational tempo. The same attack chain that might have taken a skilled team days to construct can now be automated and scaled in a fraction of the time.
In such a scenario, patch management alone is no longer sufficient. Identity-first security — unique credentials, FIDO2 MFA, granular access control, and SaaS visibility — is what will limit breach impact when exploits succeed.
On April 21, 2026, an unauthorized group gained access to Mythos. This is Anthropic's most advanced AI model, which can find and exploit critical flaws in every major OS and browser. The same ones banks, governments, and power grids worldwide rely on.
While Anthropic investigated the leak, rumors spread that a ShinyHunters impersonator was the culprit. The latter even shared screenshots of a Mythos dashboard, complete with user management panels and performance metrics. However, it has since been confirmed that the screenshots were fake.
Meanwhile, Anthropic has admitted that the breach occurred through a third-party environment, though it denies any of its core systems were accessed.
So, in effect, the most "dangerous" vulnerability discovery tool in existence was breached because someone's access wasn't properly controlled. Security researchers say you can't patch your way out of this one, but one thing is clear.
As our collective exposure to AI-related risk grows, third-party risk management and identity security will be foundational to business resilience.
The Mythos leak was an access control failure in a vendor environment Anthropic didn't directly manage.
That's the problem with third-party risk: You can surface every app your own employees are using. But you can't reach into your vendor's environment and audit how their team manages credentials.
What you can do is set the standard for access. The most effective way to extend identity security beyond your own perimeter is to require it contractually — making credential hygiene, MFA enforcement, and SaaS visibility a condition of any vendor accessing your systems.
Basically, a vendor should be able to demonstrate they're managing credentials with the same rigor you are. Encouraging them to adopt the same SaaS visibility and identity security tool your team uses (and perhaps making it a procurement condition) is the closest practical equivalent to third-party risk management a lean IT team can enforce.
How does the Mythos leak change your threat model?
The Mythos leak highlights what is increasingly plausible rather than purely hypothetical. We now have an automated adversarial capability that has compressed the discovery-to-patch window from days or weeks to mere hours.
For decades, security teams used a familiar rulebook: Discover vulnerabilities -> Prioritize -> Patch -> Rinse and repeat
What has changed with Mythos is operational autonomy, which compresses that timeline.
Mythos can identify thousands of zero-day vulnerabilities in a single session, including decades old flaws human have missed – Tech Crunch.
The reality we're facing is that vulnerabilities can now be identified, chained, and weaponized faster than most organizations can even classify them. According to ISACA, enterprise vulnerability management must now be reoriented towards exposure management.
This is proactively identifying the most critical paths an attacker might take through your environment, rather than just trying to fix every vulnerability. New exposure-based insights matter, such as:
- Blast radius risk: How many systems can a single compromised highly privileged identity access?
- SaaS and non-human identity (NHI) growth: How quickly are SaaS and AI accounts multiplying, apart from IT oversight?
- Access traceability: Can we audit and trace the actions taken by our team and AI agents?
With the Mythos leak, your risk surface now includes every SaaS and AI tool your vendors have deployed — whether you approved it or not.
AI agents need their own access controls. Your employees need theirs.
As AI tools multiply inside your organization, you have two distinct identity problems: securing the AI agents your team deploys, and securing the human credentials those agents (and attackers) can reach.
According to IBM, 97% of organizations impacted by AI incidents lacked proper access controls.
In light of the Mythos leak, ISACA recommends infrastructure changes, AI-powered vulnerability discovery, and governance frameworks — that no single product provides.
For teams of 50 to 500, the most actionable starting point is also the one with the most impact: closing the identity and SaaS visibility gaps that attackers reach first.
LastPass was built to secure the human access layer. See how it deploys in days with a free LastPass trial.
What's the actual attack path when an AI exploit runs?
Generally, when an AI exploit runs, the path may look something like this:
- Scanning to identify the target flaw in your system or supply chain
- Running the exploit and executing the payload
- A credential dump to retrieve passwords, tokens, session keys, and API keys
- Lateral movement, when harvested credentials unlock adjacent systems
- Finally, data exfiltration or ransomware deployment
Step #3 is where most breaches succeed or fail.
While exploits can take multiple paths, one commonality across the vast majority of them is the hunt for and extraction of credentials and other identity-related data.
If every credential in your environment is unique, rotated, FIDO2 MFA-protected, and scoped to least privilege, a successful exploit is far less likely to expand laterally or escalate in impact.
While identity security controls don't prevent the zero-day, it can mean the difference between a containable incident or a catastrophic disruption that takes down your business.
What does a Mythos-ready identity security stack look like for a 50-500-person team?
For teams of 50 to 500, the math is daunting. You may have a smaller IT team and budget, but you'll still have an attack surface that scales with headcount.
Three practices close the attack chain at step #3:
- Credential hygiene. According to Verizon's 2025 DBIR report, stolen credentials play a key factor in the majority of breaches. One harvested credential should not be able to unlock your entire stack.
- Scoped access. An AI agent running with admin credentials is a Mythos-level target. Granular access controls ensure each credential is scoped to one role and for only the time needed to complete a task.
- Visibility into your full SaaS footprint. Mythos-era threats don't distinguish between your managed stack and the 12 apps your team installed without IT approval. Unsanctioned apps can multiply unsecured credentials at scale.
The last one is where most security programs fail: Visibility into apps and AI tools your team adopted without IT approval.
Surfacing unsanctioned SaaS and tying those logins back to named users is what closes the identity security gap.
How does Shadow AI make containment harder and more urgent?
At the same time, many organizations are dealing with another reality: AI adoption is happening faster than governance.
Employees are experimenting with new tools. Your team may have signed up for SaaS platforms with built-in AI features.
And sensitive information, such as corporate credentials, customer data, and internal documents, are being copied-and-pasted into platforms daily without IT approval.
This is the reality of the modern office, where most work now occurs in the browser.
In combination with AI-driven innovation, the browser is now your single largest attack surface, where one compromised identity can lead to cascading access across your environment.
Ultimately, you can't realistically stop people from using AI. But you can ensure identity doesn't become your weakest link.
"A key point with AI use by attackers is that the attacks themselves aren't changing. The goals are the same and fundamentally, the TTPs are the same. The biggest changes are in speed, scale, and availability. But the same defenses largely apply (some new technologies/approaches will be required to address threats like prompt injections, but largely the current cyber defenses can still do most of the heavy lifting; we don't need to reinvent the wheel).
This could change rapidly, to be sure, but I think it's important to keep that perspective, so we don't fall victim to unnecessary panic. Defenders will also ultimately have more money and resources to apply to AI in the long run, which gives them a longer-term advantage... as long as AI advancements are handled responsibly.
The way Anthropic is handling Mythos is a good example of the right way to do it."
Mike Kosak, LastPass Director of Threat Intelligence
How does LastPass close the gap for lean IT teams?
For lean IT teams, LastPass centralizes credential management, SaaS Monitoring, and real-time reporting without requiring a dedicated security team.
Read how Axxor achieved operational efficiency and security after centralizing access management across three global sites, eliminating insecurely shared logins and enforcing SaaS Monitoring in just a few months.
Identity security for lean IT teams: How the options compare
In April 2026, a Vercel employee's unmanaged Context.ai account was compromised and used to hijack the employee's Google Workspace account and several Vercel systems.
While the Mythos leak was an access control failure in a vendor environment, the Vercel breach followed a different but equally instructive path: Attackers hijacked an unmanaged AI tool used by an employee, entirely outside SSO oversight, and used it to access internal systems.
Together, they illustrate two sides of the same third-party risk problem: the vendors and contractors you grant access to, and the tools your employees bring in without IT approval.
The reality is that SSO alone doesn't provide a complete picture of how access occurs across SaaS and AI tools.
However, LastPass provides complementary controls for non-SSO access, showing how your team is accessing apps in the browser.
| Decision lens | 1Password | Keeper | Enterprise IAM, CASB, SSPM | LastPass |
| Best for | Large enterprises with dedicated security engineers | IT or privileged access workflows; no browser-native SaaS discovery | Enterprise orgs with full security teams | Teams of 50–500 that need full visibility without complexity |
| Dedicated IT or security team needed | Depends on tier | No | Yes | No |
| Designed for 50-500 person teams | No, moving upmarket with complex XAM (Extended Access Management) platform | Yes | No | Yes, with faster "time-to-value" SaaS visibility, at a more transparent and scalable price point |
| Agentless deployment | No; requires EPM + Device Trust stack | Yes, but extension is for passwords only, not SaaS discovery | No; may require agents + considerable tuning | Yes, same extension handles both password management and SaaS discovery |
| Limits blast radius after exploit succeeds | Moderate | Moderate | Strong, but complex to operate | Strong credential hygiene + scoped access |
| Visibility into shadow SaaS / Shadow AI usage | Yes; via full XAM stack (EPM + Device Trust + SaaS Manager required; $13.99+/user/month) | No equivalent capability | Partial; requires agent + integrations | Yes, via browser extension; any app, any email domain; included in Business Max $9/user/month |
| Operationally realistic for small to midmarket teams | Depends; XAM bundle ~$13.99+/user/month; multiple integrations to configure with new capabilities likely to push price point higher | Depends; steep renewal increases and inconsistent pricing model can lead to higher total costs | No | Yes, included in Business Max at ~$9/user/month; can deploy in days |
See which credentials attackers might reach first and close those gaps in under a week → Request a 20-minute LastPass demo and receive a complimentary credential hygiene assessment.
The security decision you're actually making
Mythos didn't create a new threat.
Instead, it accelerated an existing one: the gap between when a vulnerability is discovered and when you can close it. You can't shrink that gap by patching faster. Mythos already proved that.
But you can make the post-exploit environment hostile to lateral movement.
Enforced credential hygiene, full SaaS visibility, and granular access controls can limit your blast radius regardless of what vulnerability AI finds in your code or supply chain.
LastPass has championed identity security with its industry-leading IDaaS platform for decades. This isn't new. What's new is that the Mythos leak has just made acting on identity security more urgent.
See how teams of 50–500 close their credential exposure in under a week. Trusted by millions, LastPass has consistently led the G2 Global Grid reports and in 2026, LastPass was named a G2 Best Software award winner for security products.
Sources
Anthropic: Assessing Claude Mythos Preview's cybersecurity capabilities
New York Times: Anthropic's new A.I. model sets off global alarms
Forbes: How Mythos' vulnerability apocalypse will play out (2026)
Cybernews: Anthropic investigates unauthorized Mythos access by Discord group (2026)
ISACA: Claude Mythos is Redefining the Cyberthreat Landscape
