Passkeys Vs. Passwords: Which Login Method Is Safer in 2026?
Shireen Stephenson • PublishedAugust 13, 2024 • UpdatedApril 22, 2026
Passkeys vs. passwords: Which is safer, easier, and better for your daily logins?
If you’ve always used passwords to protect your online accounts, you aren’t alone.
Many of us still rely on the trusty username‑password combo to sign in. But passwords are also the reason we keep dealing with login failures, lockouts, and hacked accounts.
With phishing implicated in 50% of all attacks, the FIDO Alliance is now calling for universal adoption of passkeys as a secure authentication method.
According to the FIDO Alliance, organizations that deploy passkeys are realizing high levels of ROI:
  • 90% increase in authentication security
  • 77% reduction in help desk calls
  • 73% increase in employee productivity
  • 83% positive impact on achieving digital transformation
  • 82% positive impact on user login experience
If you’re skeptical of passkeys in a world where passwords still exist, that’s where a clear, side‑by‑side comparison matters.
Stay with us as we talk about passkeys vs. passwords and a world where frictionless security is not only possible, but also the standard for every digital interaction.
Before diving deeper into how passkeys and passwords really compare, it’s worth experiencing a smarter way to manage both. LastPass brings passwords and passkeys together in one secure vault, so you don’t have to choose between what works today and what’s coming next. Try LastPass and see how effortless secure login can be, then let’s take a closer look at how passkeys stack up against passwords, side by side.
At a glance: Passwords vs Passkeys
Comparison area
Passwords
Passkeys
Phishing resistance
Vulnerable to phishing
Phishing resistant by design. A passkey can’t be tricked into working on a fake site, even if it looks identical to the real one
User Memory Required
High recall needed
No passwords to remember
Breach Exposure
High (server stores hashed or plaintext passwords; intercepted passwords can be reused immediately)
Low (server stores public key only; private key never leaves your device)
Cross Device Usage
Universal
Not currently universal, but expanding
Recovery Complexity
“Forgot password” flow well-understood but tedious
Losing your device can lock you out of your accounts
LastPass Support
Yes
Yes
Here’s a quick summary of the key tradeoffs:
  • Passkeys win decisively on security. They’re phishing resistant by design because the private key is cryptographically bound to the real domain (site) and never leaves your device. Passwords, by contrast, are only as secure as the choices around creation, reuse, and storage.
  • Passwords have an edge in cross-device flexibility and recovery. Although tedious, the “forgot password” flow is a known, trusted process. On the other hand, passkey recovery is still maturing. If you lose access to your synced account or device, getting back in can be tricky.
Whether you’re loyal to passwords, curious about passkeys, or somewhere in between, LastPass bridges the gap effortlessly. You get military-grade storage for legacy logins and seamless passkey support, ensuring you’re covered regardless of the path you take.
What’s a passkey?
Google, Target, Walmart, and Amazon are just a few examples of major companies that have introduced passkeys for logins.
But what are passkeys?
Think about the last time you attended a business conference or music festival. Did you purchase an all-access pass? If so, you probably enjoyed unlimited access to all events with a simple scan of your badge or wristband.
Take for example Disney’s Lightning Lane All-Access Pass. It grants you physical entry to all eligible attractions in a single Disney Park for one day.
In contrast, passkeys grant secure access to digital accounts.
So, both all-access passes and passkeys serve as “keys” for entry - but with an important difference: all-access passes grant physical entry, while passkeys enable digital access.
The secret behind passkeys: How your device replaces the humble keyword
Based on standards developed by the FIDO Alliance (Fast Identity Online Alliance), passkeys are created by generating a pair of cryptographic keys – a public key and private key – using asymmetric cryptography.
When you create an account using passkeys, your device creates a public-private key pair.
The public key is stored on the server of your favorite platform, such as Walmart, Nintendo, Roblox, Amazon, or Target. Meanwhile, the private key is stored on your device, such as your laptop or smartphone.
Instead of using a password to access your account, you’ll select passkeys on the sign-in screen and then unlock your device to prove your identity. This unlocking can be done using the method you’ve set for unlocking your device, such as a PIN, pattern, or biometrics (fingerprint or facial scan).
Your device will then sign a time-based signature with your private key, which the platform will verify with your public key - this completes the login process. Passkeys are safer than SMS-based MFA and one of the best forms of phishing-resistant authentication you can implement.
Why passwords fail even when you’re doing your best
For one, they’re easy to forget. So, you may be tempted to scribble them on Post-it notes and stick them to your monitor.
And if you practice password recycling – you’re in good company:
  • Only 6% of passwords are unique: the “1234” sequence was found in 700+ million passwords.
  • The default “password" and “admin” were used by 56 million and 53 million users respectively.
  • Users often resorted to popular names, curse words, pop culture terms, and positive concepts like love (87 million) to come up with login credentials.
  • 24 million users believe “God” will make their password secure, while 20 million users bet on “Hell” to do the trick.
When passwords are easy to guess, hackers will have an easier time cracking them – and taking over your accounts. According to the 2026 Sophos Active Adversary report, two thirds of all security incidents were traced back to compromised credentials, weak MFA, or poorly protected identity systems.
Weak or reused passwords are the #1 way attackers get in – at home and at work.
But transitioning from passwords to passkeys doesn’t have to be all-or-nothing. LastPass has your back, ensuring you’re protected in both worlds with top-tier security that adapts to your comfort level.
And as a 2026 G2 Best Software Award winner and 2025 platinum Business Titan winner, we’re trusted by millions.
FOR YOU
Perfect for your personal life
With LastPass, one master password protects everything. You’ll never forget another login.
FOR YOUR BUSINESS
Perfect for your team
Give every employee strong, unique credentials, so no one uses their pet’s name as an admin password.
Key Differences Between Passkeys and Passwords
 Are passkeys really more secure than passwords? The shortcut to phishing resistant authentication
Passwords offer only one way to authenticate a user, which makes them particularly vulnerable to data thieves.
In contrast, passkeys use cryptographic credentials tied to your device and a biometric identifier to grant access. It’s one of the most secure authentication methods you can use as it creates additional hurdles for attackers to overcome.
In the world of finance, 42% of global financial institutions report experiencing a 75% decline in payment fraud after adopting biometrics.
What are barriers to passkey adoption?
Since they aren’t user-generated, passkeys don’t share many of the downsides of passwords. Their main advantages are that they eliminate the need for password recycling, a top factor in account takeovers, and they make phishing nearly impossible.
So, why is the road to frictionless security paved with good intentions but hindered by obstacles? According to the 2025 FIDO Alliance report on passkey deployment:
  • 76% of organizations say passkeys are too complex and costly to implement.
  • 24% say it would require intensive resources to integrate passkeys with their legacy systems.
  • 56% admit they don’t have the resources or technical skills to handle the change.
  • Meanwhile, 24% say they already use other forms of secure authentication.
On the consumer side, 75% are aware of passkeys, but only 23% use them with all accounts. According to a 2024 FIDO Alliance survey, at least 20% of respondents are still asking, “What’s a passkey?” This suggests that some confusion remains about this seamless authentication method, which may explain its slow adoption across the world.
Types of passkeys in 2026
If you’re still on the fence about passkeys, this table breaks down the passkey types you’ll encounter – arming you with the knowledge to choose the most secure authentication method for your lifestyle.
Passkey type
Description
Where it’s used
Key benefit
Single device passkeys
Cryptographic keys stored on your device
Smartphones, tablets, laptops, desktops
Biometric or PIN login
Hardware security keys
Physical USB and NFC enabled devices that store passkeys offline.
Enterprise, high-security environments in sensitive industries like healthcare, defense, and banking
Phishing-resistant authentication with the highest security assurance
Brand-implemented passkeys
Passkeys tied to specific brands
Airlines (Air New Zealand), hotel chains (Hyatt), travel apps (Kayak)
Air New Zealand login abandonment rates decreased 50% after passkey adoption.
Cloud-based passkeys
Passkeys synced across devices via cloud services
Apple iCloud Keychain, Google Password Manager, Microsoft Authenticator
Seamless cross-device logins
Best practices for creating strong passwords - and the easiest way to do so
The most secure passwords aren’t based on common phrases, previous passwords, or personally identifiable details. Both CISA and NIST recommend that passwords be at least 16 characters in length and contain a mix of letters, numbers, and symbols.
But who has time to create passwords?
Fortunately, there’s an easy, safe solution.
LastPass can generate strong, random passwords, which you can customize according to NIST and CISA rules – in less time than it takes to reset a forgotten password.
Best practices for how to implement frictionless security
If you’re ready to jump into passkeys, these best practices can keep you safe:
  • Make the switch gradual: Switching from passwords to passkeys can be overwhelming. So, starting out with one or two accounts lets you get comfortable without putting a kink in your daily flow.
  • Use biometrics to enjoy faster, safer access: Using your face or fingerprint eliminates the burden of remembering passwords. Biometrics also makes it harder for your accounts to be hacked – as it’s almost impossible to duplicate or steal.
  • Register passkeys on multiple devices to avoid lockouts: If your phone is lost or misplaced, having your passkeys on other devices means you won’t lose access to your accounts. So, when you set up passkeys on one device, look for an option to add or sync it to your other devices.
Security shouldn’t depend on a single device. With LastPass, your passwords and passkeys stay accessible, protected, and easy to recover,  no matter where you log in.
Related articles
How can I use passkeys with LastPass?
As the drumbeat for secure, frictionless authentication intensifies, many say it’s a matter of time before passwords become largely obsolete.
Yet, if you’re still using passwords, it probably has nothing to do with the tech. It’s likely you aren’t quite ready to give up on them. That said, juggling passwords on Post-it notes or a notebook can put your security at risk.
With an advanced password manager like LastPass, you can take control by keeping your passwords or passkeys secure, organized, and instantly accessible. As G2’s Spring 2025 Global Leader in frictionless authentication and platinum Business Titan winner, we’re trusted by millions across the world.
Whether you’re using passkeys or passwords, protect yourself today by trying LastPass for free (no credit card or commitment required).
FAQs: Passkey vs password
Unlike passwords, passkeys eliminate risks associated with AiTM (adversary-in-the-middle), credential stuffing, replay, brute force, and phishing attacks. Users must be physically present, usually by performing an action on their device, to gain access to accounts. Passkeys are also URL specific, which means they won’twork for logins on a phishing site. Ultimately, passkeys are a secure alternative to traditional passwords.
Yes, you can still use a password, even if you have a passkey. Many platforms such as Amazon and PayPal support both, allowing you to sign in with a passkey or fall back on a password if needed.
Yes, LastPass supports passkeys. As of August 2025, you can create, store, and manage passkeys right inside your LastPass vault—alongside your regular passwords. There’s nothing separate to set up.
What this means for you
For personal users
Skip the password. Use your face or fingerprint instead.
When a site offers a passkey option, LastPass saves it just like a password. The next time you log in, you’ll simply tap or glance instead of typing. Passkeys work across your phone, laptop, and browser.
For business teams
Roll it out for your whole team from your admin console.
Admins can enable passkey support using the Allow passkeys policy for assigned users. Employees get smoother logins with no passwords to reuse or forget, while businesses reduce their attack surface from day one.
How to get started with passkeys in 2 minutes
  1. Update your LastPass browser extension or mobile app to the latest version.
  2. Visit any site that supports passkeys (check the FIDO Passkey Directory for a growing list).
  3. When prompted to create a passkey, LastPass will offer to save it. Accept—and you’re done.
The main disadvantage of passkeys is that they aren’t universally supported by the majority of brands and platforms. And unless they’re synced across multiple devices, you may be locked out of apps and services you’ve secured with passkeys.
The best place to store a passkey is on your device such as a smartphone. You can also store it securely in FIDO2 hardware keys like YubiKey. For example, the latest YubiKey 5 Series can store up to 100 passkeys.
