When you add a new tool to your tech stack, deployment speed makes a real difference. The sooner your team starts using a password manager, the faster everyone gets strong, unique passwords protecting their accounts instead of reusing the same weak ones across multiple sites.
When you’re onboarding a new hire, the best password managers connect to your existing identity provider (such as Microsoft Entra, Okta, or Google Workspace) and create accounts automatically. LastPass uses automated setup to get you up and running on the same day.
This guide covers password managers that make onboarding quick and simple. You'll find options that work with the systems you already have in place.
Quick guide: 6 best password managers for quick deployment & onboarding
- LastPass: Best overall password manager for quick deployment and onboarding, according to G2 global grid reports
- Keeper: Fast setup with identity provider integrations
- NordPass: Simple import from browsers and other password managers
- Bitwarden: Integrations with Azure AD, Okta, and more
- Dashlane: Sets up in 15 minutes
- 1Password: Complete launch kit for team rollouts
How we evaluated the best password managers for quick deployment & onboarding
We selected these password managers based on how quickly you can set them up and get your team working securely across their devices. The best tools eliminate manual setup steps and work with your existing systems right away.
Here are some features to consider when you’re looking for a new password manager:
- Setup speed: How long until employees can start saving passwords?
- Automatic account creation: Does the platform create accounts automatically when someone joins?
- Work login integration: Can it connect to your existing identity provider?
- Onboarding resources: Are training materials and guides included?
- Importing logins: Can it bring in passwords from browsers or other tools?
- Support availability: Is help there if your team needs it during setup?
- Learning curve: Can non-technical employees figure it out easily?
The 6 best password managers for quick deployment & onboarding
1. LastPass: Best overall password manager for quick deployment & onboarding
LastPass gets your new employees working securely the same day they join your team. When someone starts automatic account creation through your work login system sets them up instantly. They log in once with their work credentials and LastPass is ready to go.
The platform connects directly to Microsoft Entra ID, Okta, Google Workspace, and OneLogin. This means you can use the systems you already have without having to add new infrastructure. When an employee leaves, their access gets revoked immediately through the same system.
Your new team members can follow an interactive guide called Start & Explore that walks them through the basics, but most people figure out the rest just by using LastPass. Thebrowser extension saves passwords automatically as they work, so there's nothing extra to remember. If anyone wants more training, there's a self-paced course that takes about 30 minutes.
LastPass features
- Automatic account creation: Creates and removes accounts instantly through your work login system
- Pre-built integrations: Connects to over 1,200 work applications your team already uses
- Interactive onboarding: Start & Explore guides new users through setup
- Browser extension deployment: Silently deploys on managed devices so employees can start saving passwords and use shared logins right away
LastPass pros and cons
Pros:
- "This group-based model makes it much easier to onboard or offboard users from shared credentials quickly and securely." – verified review
- "We have over 30 employees and 25 online tools and software platforms, and this is the best way to save those links and passwords." – verified review
- "Rollout is very easy and works across most operating systems that we have needed it to work on." –verified review
Cons:
- "Some websites cannot integrate the single sign-on function well, especially those with two-factor login or multiple login screens." –verified review
- "The number of features is good, but the settings menu can feel cluttered for new users." –verified review
- "I found setting up LastPass quite straightforward, but it was a bit trickier to set up on my iPhone." –verified review
2. Keeper: Fast setup with identity provider integrations
Keeper deploys vaults to your employees in minutes through built-in connections to systems like Entra ID, Okta, and Google Workspace. When users log in for the first time, they're automatically routed to their work login system and their account gets created on the spot.
The implementation team helps you set up everything quickly, and most employees can finish training in under 2 hours.
Keeper features
- Instant account setup: Creates accounts automatically when SSO is set up or users accept an invite and authenticate via identity provider
- Built-in connections: Works with major login systems without complex setup
- One-Time Share: Lets new employees safely retrieve credentials during onboarding
(Platform features reflect the information available on the Keeper website as of the publication date.)
Keeper pros and cons
Pros:
- "Ease of use, ease of deployment, and the overall security of the solution." –verified review
- "The import functionality offered a seamless migration without any complications." –verified review
- "Keeper is easy to use and easy to train users on." –verified review
Cons:
- "The Admin console UI/UX is very bloated and not the easiest to navigate and understand password policies and set up organisation-wide." – verified review
- "The cost can increase depending on the number of users required." –verified review
- "A more streamlined and user-friendly design would improve the overall experience." –verified review
3. NordPass: Simple import from browsers and other password managers
NordPass integrates with Entra ID, MS ADFS, Okta, and Google Workspace to create user accounts automatically. The import process brings passwords directly from browsers like Chrome, Firefox, Edge, and Safari without requiring manual entry.
On the Enterprise plan, you get face-to-face onboarding sessions and a dedicated account manager. Training takes less than 2 hours on average.
NordPass features
- Work login integration: Connects to major identity providers with accounts created when users first log in
- Direct browser import: Brings in passwords from all major browsers automatically
- Face-to-face onboarding: In-person or virtual sessions included with Enterprise plan
Platform features reflect the information available on the NordPass website as of the publication date.)
NordPass pros and cons
Pros:
- "Easy to onboard even for non-technical team members." –verified review
- "Setup was quick and the interface is clean, I like the fact that you can choose the site- or field- specific behavior." –verified review
- "The interface is intuitive, and our team quickly adapted to it." –verified review
Cons:
- "There's a bit of a learning curve, especially for people who aren't very tech savvy." –verified review
- "It can take a while to understand how to log in." –verified review
- "It would be helpful to allow more granular control, like sharing a single login from within a folder." –verified review
4. Bitwarden: Integrations with Azure AD, Okta, and more
Bitwarden reports 70% of business customers are onboarded in less than a month. The platform connects with Azure AD, Okta, OneLogin, and JumpCloud to create and remove accounts automatically.
If you use a different system for managing employee logins, Bitwarden offers a Directory Connector tool that syncs users and groups from your existing setup. You also get weekly live training sessions and support from a customer success manager during onboarding on the Enterprise plan.
Bitwarden features
- Real-time account creation: Integrations create and revoke accounts instantly
- 70% deployed in under a month: Fast implementation for most teams
- Directory Connector: Alternative sync option for on-premise directory services
(Platform features reflect the information available on the Bitwarden website as of the publication date.)
Bitwarden pros and cons
Pros:
- "Setting up and managing passwords is straightforward, making it ideal for my company's employees." –verified review
- "Our team is able to set it up easily and quickly within our customer's work environment." –verified review
- "The setup was quick and painless, and the interface is clean and easy to navigate." –verified review
Cons:
- "The UI feels a bit outdated compared to some competitors." –verified review
- "The autofill option is very disappointing since it fills the wrong password sometimes and I manually have to type it." –verified review
- "Sometimes the autofill feature can be inconsistent on some browsers." –verified review
5. Dashlane: Sets up in 15 minutes
Dashlane's setup takes about 15 minutes and works with most login systems. The platform handles authentication through secure cloud servers, so you don't need to set up complex encryption services yourself.
Accounts get added automatically when employees first log in, and admins can push the browser extension out to everyone's computers through GPO, Microsoft Intune, and Jamf without employees needing to install anything manually.
Dashlane features
- 15-minute setup: Quick deployment that works with most login systems
- Automatic user management: Creates and manages user accounts through your work login system
- Push extension to all computers: Install to everyone's computers through GPO, Intune, and Jamf
(Platform features reflect the information available on the Dashlane website as of the publication date.)
Dashlane pros and cons
Pros:
- "I like the ease of onboarding users and how it lets them keep their personal passwords separate from company related websites." –verified review
- I have never used a password manager and, once I got used to it, it was easy to use and is very responsive." –verified review
- "We have a corporate account and I like that I can deactivate staff and it's easy to implement across the organization." –verified review
Cons:
- "One thing we've noticed is how difficult it is to reset a master password." –verified review
- "Dashlane has issues with some sites, especially ones with a third authentication field." –verified review
- "At times, the autofill for fields can be a bit aggressive, and Chrome on Android doesn't work well with it." –verified review
6. 1Password: Complete launch kit for team rollouts
1Password offers a Launch Kit with email templates, video walkthroughs, FAQ documents, and presentation slides that help you communicate the rollout to your team. Once you're ready to deploy, the integration connects to Azure AD, Okta, and Google Workspace to create user accounts automatically (requires SCIM bridge hosted by customer).
This setup means employees can sign in using their work login credentials instead of creating separate passwords to remember.
1Password features
- Complete Launch Kit: Ready-made materials including email templates and video guides
- Automatic account creation: Integration with major work login systems creates accounts automatically (requires SCIM bridge hosted by customer)
- Sign in with work credentials: Employees use their existing work login instead of separate passwords
(Platform features reflect the information available on the 1Password website as of the publication date.)
1Password pros and cons
Pros:
- "We've implemented it within a month, all went good and our adoption rate is great." –verified review
- "Very professional service form start to end, very slick product and easy onboarding process." –verified review
- "The increased security we have is achieved by the simple onboarding and use for each new team member." –verified review
Cons:
- "Big learning curve for people who have not used a password assistant." – verified review
- "I understand it is for security purposes but it does mean it takes a bit longer to get to my passwords." –verified review
- "The autofill feature doesn't work smoothly across all websites or browsers." –verified review
How do I set up a password manager for my team?
Start by connecting your password manager to your work login system like Microsoft Entra ID or Okta so accounts get created automatically. This automated connection creates accounts for your employees without manual setup. You'll configure this once through your admin console.
Next, deploy the browser extension to your team's computers. Many platforms let you push this out automatically through group policy or mobile device management tools. When employees log into websites, the password manager saves their credentials automatically. They don't need to change how they work.
Training usually takes 30 minutes to 2 hours depending on the platform. Most people learn by using it naturally throughout their day rather than sitting through formal sessions.
Which password manager is best for beginners?
LastPass works well if you have employees who are new to password managers. The Start & Explore onboarding walks them through 5 simple tasks during their first month. As they browse and log in to websites, LastPass automatically saves and fills their passwords.
The interface uses a familiar folder system that feels natural to most people, so there’s no need to learn new concepts or technical terms. There’s also a 30-minute self-paced course that covers the basics.
Why LastPass is the best password manager solution for quick deployment & onboarding
LastPass gets your entire team working securely and fast. Accounts get created automatically through your existing work login system when employees join. The browser extension deploys automatically too, so passwords get saved as people log in to apps and websites as they work.
New users can follow the Start & Explore guide, which walks them through setup with interactive tasks. This means your team masters the platform through regular use rather than sitting through formal training sessions. When someone wants to check their security status, the visual Security Dashboard shows password health in simple scores anyone can understand.
Ready to simplify password management for your entire team? Try LastPass now and see why organizations trust us for fast, secure deployment.
