6 Best Password Managers for Android in 2026
LastPass • PublishedNovember 05, 2025
Your Android phone holds the keys to your digital life. From banking apps to social media accounts, you're likely logging in to dozens of services every week. A good password manager makes it easy to keep all those credentials secure while still getting into your accounts quickly.
The best password manager for Android works quietly in the background. When you open an app or website, your login details appear automatically. You tap once and you're in.
This guide covers 6 password managers that work well on Android. LastPass leads the list because it's consistently rated highest for combining strong security with a simple user experience.
Quick guide: 6 best password managers for Android
  1. LastPass: The best overall password manager for Android according to G2 global grid reports
  2. Bitwarden: Open-source option with self-hosting capability
  3. 1Password: Travel Mode temporarily hides sensitive vaults when crossing borders
  4. Dashlane: Offers WearOS smartwatch app for passwords and passkeys
  5. Keeper: Includes offline vault access on mobile devices
  6. NordPass: Has OCR scanner for capturing credit cards with your camera
How we evaluated the best password managers for Android
We selected these password managers based on how well they perform on Android devices specifically. Your phone is different from your desktop, so we focused on features that matter most when you're logging into apps on the go:
  • Android autofill reliability: Does it fill passwords consistently across apps and browsers?
  • Biometric unlock: Can you get into your vault with your fingerprint or face?
  • Offline access: Can you view passwords without an internet connection?
  • Cross-device sync: Do passwords saved on your phone appear on your other devices?
  • Battery impact: Does the app drain your battery or slow down your phone?
  • App integration: Does it work well with Android's native autofill framework?
The 6 best password managers for Android
1. LastPass: Best overall password manager for Android
LastPass gives you a fast, reliable way to manage passwords on your Android phone. The app uses your fingerprint or face to unlock your vault, so you can get to your passwords without typing your master password every time. When you open an app that needs a login, LastPass recognizes the password field and offers to fill it in with one tap.
The Android app syncs instantly with all your other devices. Save a password on your phone and it's immediately available on your laptop, tablet, or any other device where you use LastPass.
LastPass also supports passkeys on Android, letting you log into sites like Google and Amazon without typing a password at all. The familiar folder system makes organizing hundreds of passwords simple, and the app matches your phone's dark mode setting automatically.
LastPass features
  • Passwordless biometric login: Unlock your vault using Face ID, fingerprint, or Android biometric scanning without entering your master password.
  • Android Accessibility Service: Enables autofill across all apps and browsers, including older Android versions that don't support native autofill.
  • Mobile passkey support: Save and use passkeys for major sites like Amazon and Google directly from the mobile app.
  • Automatic cross-platform sync: Passwords saved on mobile instantly appear on all your connected devices.
  • Dark mode support: The app automatically matches your phone's system settings for comfortable viewing.
  • Security Dashboard: Shows your password health scores so you know which credentials need updating.
LastPass pros and cons
Pros:
  • "So easy to auto fill and to create very strong passwords." –verified review
  • "I really like the password vault and how you can copy/paste usernames and passwords easily in various applications on multiple devices." –verified review
  • "Works seamlessly with all extensions on every browser. Easy to manage shared passwords across groups, and very simple to share and retract access to passwords." –verified review
Cons:
  • "I wish I knew how to see my passwords easier." –verified review
  • "Nothing to dislike! If they had a VPN service that would be amazing!" –verified review
Bitwarden is an open-source password manager, which means anyone can review the code for security vulnerabilities. For users who want complete control over their data, Bitwarden also offers a self-hosting option that lets you run your own server.
The app supports passkeys and biometric unlock, so you can get into your vault with your fingerprint or face. If you travel frequently, the offline mode keeps your passwords accessible even without an internet connection.
Bitwarden features
  • Open-source code: Transparent security that anyone can audit.
  • Self-hosting option: Allows running a personal server for complete data control.
  • Biometric authentication: Supports fingerprint and face recognition.
(Platform features reflect the information available on the Bitwarden website as of the publication date.)
Bitwarden pros and cons
Pros:
  • "Easy to use, works across multiple platforms (I have it on my PC, Android mobile, iPad)" –verified review
  • "I like having all my password in one place for convenience, but without losing any level of security." –verified review
  • "It has a ton of features but does not bombard you with them." –verified review
Cons:
  • "Sometimes the autofill feature can be inconsistent on some browsers." –verified review
  • "Some screens of the app still have accessibility issues, such as buttons without labels and screens overlapping each other." –verified review
  • "I think the UI could do with a revamp, and be more seamlessly integrated into the browser experience, that also goes for mobile." –verified review
1Password offers Travel Mode, which hides specific vaults from your device when you're going through airport security or customs. Your data stays protected from unwanted searches, and you can restore everything once you're through.
1Password also requires a Secret Key alongside your master password when logging in on a new device. This adds an extra layer of protection, but it also means you'll need to store that key somewhere safe to avoid getting locked out.
1Password features
  • Travel Mode: Temporarily hides sensitive vaults from the device when crossing borders.
  • Watchtower alerts: Sends notifications when passwords appear in data breaches.
  • Passkey support: Works with passkeys on Android 14+ devices.
(Platform features reflect the information available on the 1Password website as of the publication date.)
1Password pros and cons
Pros:
  • "Helps users securely store and manage passwords, financial details, documents, and other sensitive information." –verified review
  • "Polished user interface, on all devices (PC, Android, etc)." –verified review
  • "1Password's navigation (vaults) makes it really easy to group related passwords together." –verified review
Cons:
  • "It lags a bit and when passive for a certain time, it kicks you out, so you have to login or re-authenticate." –verified review
  • "Sometimes logging into it is challenging depending on what device you are using." –verified review
  • "FaceID doesn't always work on the mobile app." –verified review
Dashlane works on your Android watch as well as your phone. The WearOS app gives you quick access to credentials when your phone isn't handy.
The mobile app syncs automatically across devices and keeps an offline copy so you can view passwords without an internet connection. Dashlane also includes AI-powered phishing detection that warns you before you enter credentials on suspicious sites.
Dashlane features
  • WearOS smartwatch app: Passwords and passkeys accessible from an Android smartwatch.
  • Offline access: Saved passwords remain available without an internet connection.
  • Biometric unlock: Supports fingerprint and face recognition.
(Platform features reflect the information available on the Dashlane website as of the publication date.)
Dashlane pros and cons
Pros:
  • "The Password Health monitoring is nice. It makes it easy to see which passwords need improvement and make those updates." –verified review
  • "It's easy to use, saves time and makes the process of sharing passwords between people to be very easy." –verified review
  • "I like that passwords fill in very quickly and effectively." –verified review
Cons:
  • "The mobile app is glitchy, and often doesn't stay logged in." –verified review
  • "I dislike logging into Dashlane every 14 days for it to work properly." –verified review
  • "You can't share a group of passwords, you can only share one at a time." –verified review
Keeper stores an encrypted copy of your vault locally on your Android device, so you can access passwords even when you have no internet connection. This is helpful when traveling or in areas with poor connectivity.
The app unlocks with your fingerprint or face, and includes a built-in TOTP authenticator that generates two-factor codes right in the app. Keeper also has a WearOS app that puts your most-used passwords and codes on your wrist.
Keeper features
  • Offline vault access: Passwords remain accessible without an internet connection using locally encrypted data.
  • Built-in TOTP authenticator: Generates two-factor codes directly in the app.
  • WearOS smartwatch app: Credentials and TOTP codes accessible from an Android watch.
(Platform features reflect the information available on the Keeper website as of the publication date.)
Keeper pros and cons
Pros:
  • "Browser and app flexibility makes using the tool very easy to use." –verified review
  • "Keeper makes it easy and convenient to store strong passwords and utilize them across different devices." –verified review
  • "The implementation was very easy and it integrates with all browsers, iOS and Android." –verified review
Cons:
  • "Keeper extension autofill sometimes replaces fields we don't want, and we need to temporarily disable it." –verified review
  • "Autofill doesn't work with as many websites as some other competitor password managers." –verified review
  • "The pricing has been really inconsistent with a 20% rise this year." –verified review
NordPass includes an OCR scanner that lets you add credit cards to your vault just by pointing your phone's camera at them. The app reads the text and saves it automatically, so you don't have to type in card numbers manually.
The app uses biometric unlock with fingerprint and face recognition, and syncs your passwords across all your devices. NordPass also keeps an offline copy of your vault, though you'll need to reconnect to make any edits.
NordPass features
  • OCR card scanner: Captures credit card details using the phone camera.
  • Cross-platform sync: Passwords stay updated across all devices.
(Platform features reflect the information available on the NordPass website as of the publication date.)
NordPass pros and cons
Pros:
  • "Good mobile app, clean interfaces and reasonable pricing." –verified review
  • "It saves all my passwords in one place and fills them in when I need them." –verified review
  • "Easy to use, intuitive and being cloud-based, accessible on all of my devices." –verified review
Cons:
  • "Sometimes, it interferes with the login screens of certain apps." –verified review
  • "When going from mobile to web some sites aren't immediately recognized." –verified review
  • "The browser extension occasionally logs out or takes a bit to sync across devices." –verified review
Comparison table: The best password managers for Android
Platform
Free Trial
Hardware Key 2FA
Emergency Access
LastPass
30 days
Customizable wait
Bitwarden
No trial
Customizable wait
1Password
14 days
Uses Emergency Kit
Dashlane
14 days
Manual only
Keeper
30 days
Customizable wait
NordPass
14 days
7-dayperiod
What features should I look for in an Android password manager?
The most important feature is reliable autofill. Your password manager should recognize login screens across all your apps and browsers, then fill in your credentials with a single tap. Look for apps that use Android's native autofill framework and also support the Accessibility Service for older apps that don't work with the newer system.
Biometric unlock is the second must-have. Being able to open your vault with your fingerprint or face makes the difference between a password manager you use every day and one you abandon after a week. The best apps let you stay logged in while still requiring biometric verification each time you access sensitive data.
Cross-device sync matters too. When you save a new password on your phone, it should appear on your laptop and tablet within seconds. This keeps everything consistent and means you're never stuck without a password you need.
How do I set up a password manager on my Android phone?
Start by downloading the app from the Google Play Store and creating an account. You'll choose a master password during setup. Make this password strong and memorable since it's the key to everything else.
Next, enable autofill in your Android settings. Go to Settings, then Passwords & accounts, then Autofill service, and select your password manager. The app will guide you through granting the necessary permissions.
Finally, import your existing passwords. Most password managers can pull credentials from Chrome or other browsers you've used. You can also import from another password manager if you're switching. After that, just use your phone normally and the app will offer to save new passwords as you create them.
Why LastPass is the best password manager for Android
LastPass makes password management on Android feel natural. The app recognizes password fields across apps and websites, fills in your credentials with one tap, and stays out of your way the rest of the time. Biometric unlock means you're never fumbling with your master password when you just want to check your email.
The automatic sync keeps every device in your life connected. Save a password on your phone during lunch and it's waiting on your laptop when you get back to your desk. The Security Dashboard shows you which passwords need attention, so you can gradually strengthen your accounts without tackling everything at once.
LastPass Premium and Families plans include emergency access, letting you choose trusted people who can request vault access if something happens to you. You also get dark web monitoring that alerts you when your information appears in data breaches.
Ready to secure your Android device?Try LastPass now and see how much easier password management can be.
FAQs about password managers for Android
Password managers are one of the safest ways to protect your accounts on Android. They encrypt your passwords with strong algorithms, require your master password or biometrics to unlock, and generate unique passwords for every account. This is far more secure than reusing passwords or keeping them in a notes app.
Yes. Modern password managers integrate with Android's native autofill framework, which means they can fill passwords in any app that supports it. LastPass also uses the Accessibility Service to fill passwords in older apps and browsers that don't support the newer autofill system, giving you coverage across your entire phone.
Google Password Manager handles the basics well, but it only works within Chrome and Google apps. A dedicated password manager like LastPass fills passwords across all your apps and browsers, generates strong unique passwords, monitors for data breaches, and lets you share credentials securely with family or teammates.
LastPass offers the best experience on Android with reliable autofill across apps and browsers, fast biometric unlock, and instant syncing to all your devices. The app supports passkeys for passwordless login to major sites and includes a Security Dashboard that helps you identify weak passwords. You can try it free for 30 days.
LastPass offers a free tier that includes unlimited passwords, automatic saving, and a password generator. You can use it on one device type for free. If you need access across both mobile and desktop, the Premium plan adds cross-device sync, emergency access, and priority support.
Google Password Manager saves and fills passwords in Chrome and Android apps signed into your Google account. A dedicated app like LastPass works across all browsers and devices, includes advanced features like password sharing and breach monitoring, and doesn't tie your security to a single company's ecosystem.
