Security To-Do's
Clear out data stored in your browser(s). Don’t let passwords, credit cards, and other personal data lurk in your browser(s) where there’s few security features to lock them down. Review and remove any saved information. (Here’s where to find them.)
Run updates to your software. If you’ve been skipping all those prompts to update your browsers and other programs, now’s the time to run them. Reboot your computer and relaunch any apps or browsers to let updates run.
Uninstall unused apps. You’ve probably downloaded software, browser extensions, and smartphone apps that you never really got around to using. Use your device’s control panel to review installed apps or programs, and remove those you no longer use.
Run antivirus, if you aren’t already. That goes for you Mac users, too. Everyone should be running antivirus software on computers and smartphones to defend against common malware and viruses. There are many free and paid options available.
Add timeout locks to your devices. Setting a lock on your desktop or smartphone is an easy but effective way to prevent someone from getting in. Set a timeout after a few minutes of inactivity and choose a complex PIN or passcode to unlock it.
Backup your data. Whether you choose a hard drive or a cloud service, create a system to backup your photos, documents, and other personal files. And then make sure you do it regularly, especially if it’s not set to auto-backup!
LastPass To-Do's
Use a password manager. If you’re reading this, you probably already use LastPass. But if you’re new to password management, download LastPass for free today so you can organize your passwords and encrypt them for safe storage.
Keep your email address(es) up-to-date. Check your email and security email addresses in account settings. If either changed, update them now. Many important LastPass security features require email access, so keep your LastPass account up-to-date.
Turn on two-factor authentication. Two steps are more secure than one. With two-factor authentication, you require what you know (a master password) and something you have (a code or key) before accessing your vault. LastPass supports many options.
Audit passwords with the Security Challenge. Are your passwords strong enough? Launch the Security Challenge from your vault to find weak, reused, old, and compromised passwords, then make them stronger and improve your score.
Set autologoff. Keep your LastPass account safe from prying eyes by logging off automatically. In the LastPass browser extension, open the Preferences menu to enable autologoff automatically after the browser is closed or goes idle.
Review trusted devices. From your LastPass vault, open the Account Settings and review both your trusted devices as well as your mobile devices. Remove any that you no longer use or that you no longer want to be “trusted” by LastPass.
Share LastPass with friends and family. Help others use stronger passwords that will keep them safe online. Use the friend referral option so you both earn Premium benefits!
