When you're building out your team, you want everyone set up for success from day one. That includes giving them clear guidelines for how to handle passwords, so they can stay secure without having to think too hard about it.
A good password policy makes life easier for everyone. Employees know exactly what's expected, IT spends less time resetting forgotten credentials, and your business stays protected. LastPass helps growing teams put these standards into practice by handling credential management and policy enforcement automatically.
This guide walks you through ten password standards worth building into your policy. We'll cover what each one means, why it matters, and how to make it happen.
Key takeaways: password standards every growing business needs
- Longer passwords beat complicated ones, so aim for 14 characters minimum instead of focusing on symbols and numbers.
- Forcing employees to change passwords on a schedule often backfires because people start making predictable tweaks.
- Multifactor authentication (MFA) adds a second step to logins, which means a stolen password alone won't get attackers in.
- LastPass helps you enforce password rules automatically through over 100 customizable security policies.
- Scanning the dark web for leaked credentials catches problems early, before stolen passwords cause real damage.
10 password standards your growing business should follow
1. Require a minimum password length of 14 characters or more
When it comes to password strength, length wins. A 14-character password is dramatically harder to crack than an 8-character one, even if the shorter version has a bunch of symbols thrown in.
Every extra character multiplies the possible combinations an attacker would need to guess. That's a lot of extra work for anyone trying to break in.
Encourage your team to think in passphrases instead of passwords. Something like "CoffeeTableBlueMountain" is both stronger and way easier to remember than "P@ssw0rd!". Set 14 characters as your minimum, and don't cap the maximum length. Longer is always better here.
2. Ban commonly used and compromised passwords
Even a long password won't help if it's already floating around on a list of stolen credentials. When a breach happens somewhere else, attackers take those leaked passwords and try them on other sites to see if anyone reused them.
Your policy should block passwords that show up in known breach databases. That includes obvious ones like "password123," but also things employees might default to, like your company name or common industry terms.
Automated screening catches these weak choices before they become a problem. It's a simple way to protect employees who might not realize their "clever" password is actually pretty common.
3. Eliminate mandatory password expiration schedules
This one surprises a lot of people: forcing regular password changes can make you less secure. When employees have to create new passwords every couple of months, they tend to take shortcuts. They'll add a "2" at the end, swap an "a" for an "@," or just rotate through a handful of similar passwords.
Security experts now recommend skipping arbitrary expiration dates altogether. A strong password that hasn't been compromised is still strong six months later.
Save mandatory changes for when they matter: someone leaves the company, you suspect a breach, or an employee's role changes in a way that affects their access.
4. Enforce multifactor authentication on all accounts
A password on its own isn't enough to protect business accounts. Multifactor authentication adds a second check when someone logs in. So even if an attacker gets hold of a password, they still can't get into the account without that second piece.
The second factor could be an authenticator app on your phone, a physical security key, or biometrics like a fingerprint. Text message codes work too, though they're a bit easier for attackers to intercept than other options.
Start by rolling out MFA on your most sensitive accounts: email, financial systems, and anything with admin access. Once employees get used to the extra step, it becomes second nature.
5. Use a password manager to generate and store credentials
Nobody can memorize dozens of unique, random passwords. And when you expect people to do the impossible, they find workarounds. They reuse passwords. They write them on sticky notes. They pick something easy to remember (and easy to guess).
A password manager solves this by creating strong, random passwords for every account and storing them securely. When someone needs to log in, the password fills in automatically.
Look for a password manager with apps and browser extensions for all the devices your team uses, including phones. That way, employees can access their credentials wherever they're working.
6. Establish unique passwords for every account
When employees use the same password across multiple services, a breach at one of those services can expose the others. If someone's personal shopping account shares a password with their work email, both are only as secure as the weakest link.
Every business account should have its own unique password. That goes for internal systems, cloud apps, and third-party tools alike. A password manager makes this easy by generating and remembering a different password for each login.
7. Define clear policies for sharing passwords internally
Some passwords need to be shared. Maybe it's a social media account, a vendor portal, or a subscription service the whole team uses. The question is how people share them.
Without a secure option, employees get creative in all the wrong ways. They email passwords, drop them in chat, or scribble them on paper. None of that is safe.
Secure sharing means the password stays encrypted, and you control who can see it. Good sharing tools let you grant access without revealing the actual password, and they keep a record of who accessed what.
Put together simple guidelines: which accounts can be shared, who approves access, and how sharing should happen. Make it easy for employees to do the right thing.
8. Require immediate password changes after employee departures
When someone leaves your company, every password they knew is a loose end. That includes shared accounts, team logins, and vendor portals. If those credentials stay the same, your former employee could still access them.
Build password rotation into your offboarding checklist, and aim to update shared credentials on or before the person's last day.
Individual accounts are easier to handle. Tools that connect to your company directory can automatically remove access when someone's account is deactivated. But shared passwords need manual attention, so make sure they're part of your process.
9. Monitor for breached credentials with dark web scanning
Sometimes credentials get stolen and end up for sale online before anyone realizes there's been a breach. Dark web scanning keeps an eye out for your company's email addresses and passwords in those databases.
When a match pops up, you can act fast. Reset the password before an attacker has a chance to use it. It's a simple shift from reacting after something goes wrong to catching problems early.
This kind of monitoring runs in the background, checking constantly so you're not waiting for a quarterly security review to find out about exposures.
10. Document your password policy and train employees on it
Most people aren't going to dig through a 20-page security document to find out what's expected of them. Keep your policy short and readable. Cover the essentials: how long passwords need to be, why reusing them is risky, where MFA is required, and what to do if something seems off. Write it like you're explaining it to a friend, not drafting a legal contract.
Then make time for training, especially when onboarding new hires or rolling out changes. Help people understand the "why" behind each rule. When employees see password security as something that protects them personally, not just a box to check, they're much more likely to follow through.
How LastPass helps you enforce password standards
Setting up solid password standards is one thing. Getting your whole team to follow them, every day, without constant reminders, is another challenge entirely.
LastPass makes it easier by handling a lot of the heavy lifting for you. Once you set your policies, they're enforced automatically. No nagging, no chasing people down.
With LastPass Business, you get over 100 customizable security policies. You can set minimum password lengths, require MFA for vault access, and control who can share what, all from one Admin Console. It's designed to be straightforward, even if you don't have a dedicated IT team.
The built-in password generator creates strong, unique passwords on the spot. Employees don't have to come up with them or try to remember them. And the Security Dashboard shows you password health across your organization, so you can spot weak, reused, or compromised credentials at a glance.
Dark web monitoring runs quietly in the background, alerting you when employee credentials show up in breach databases. That early warning gives you time to act before a leaked password turns into an actual incident.
And if you ever run into trouble, LastPass Business includes 24/7 support by phone, email, or chat.
Start your free LastPass Business trial and see how much easier password management can be.
