Removing the First Barrier to Secure Access: LastPass Mobile Smart Scanner
Shireen Stephenson • PublishedJune 17, 2026
Key takeaways: Mobile Smart Scanner
  • Mobile Smart Scanner is an intelligent password scanner that removes the biggest barrier to using password managers: Getting credentials into a secure vault.
  • Mobile Smart Scanner is now generally available to all customers, including business users.
  • This new capability is designed to improve employee adoption and accelerate time-to-value.
  • Mobile Smart Scanner is exclusive to LastPass, giving you the ability to scan credentials into fully usable, autofill-ready vault entries instantly.
Secure access starts with a simple truth: You can't protect what you can't access securely.
And for most people, the first step of getting passwords into a secure vault is where momentum breaks down.
Before Zero Trust, autofill, or Dark Web Monitoring can keep you safe, there's one foundational step everything depends on: capturing and securing every login.
Getting this first step right sets the stage for secure access.
That's why Secure Access Essentials begins with something simple: removing friction from how you enter passwords into your vault.
As a first in the password management space, we're introducing Mobile Smart Scanner to remove that friction.
The one change that makes every login in your life easier
In 2026, the work-life boundary has shifted.
Work follows you everywhere.
You're switching between devices and logging into dozens of accounts daily.
At the same time, your passwords are stored in too many places. And you're reusing them across sites because it's easier.
Unfortunately, that also makes account takeovers far more likely.
As the threats rise, secure access is no longer optional — it's essential. That means simplifying the way your passwords move from paper to secure vault isn't just about convenience.
When you can quickly get your credentials organized, security feels intuitive and less like a chore. This one simple shift keeps you safer.
Innovation in security matters. Instead of asking you to change how you live, we focused on making security work the way you live, so it stops being something you avoid and starts being something that just works for you.
Introducing LastPass Mobile Smart Scanner: Password management that works the way you do
Mobile Smart Scanner is an intelligent password scanner that's available only in LastPass.
Built directly into the LastPass mobile app, Smart Scanner lets you use your phone's camera to scan typed or handwritten passwords and turn them into ready-to-use password vault entries.
Simply:
  • Open your LastPass mobile app.
  • Scan the credentials.
  • Review detected fields such as site, username, and password.
  • Save to your vault.
The credentials you save with Smart Scanner are fully functional entries that can be auto filled like your other stored credentials.
This means no more delays, errors, or missed accounts.
And since we know secure access requires trust, Smart Scanner works entirely on your device, so your scans stay private. Credentials and images aren't stored or sent to LastPass, and you stay fully in control at every step. The result is a seamless experience that prioritizes ease and trust.
Why Mobile Smart Scanner matters for your business
For organizations, the biggest challenge with Secure Access is adoption.
Mobile Smart Scanner addresses this by removing the friction that prevents your employees from getting started.
Built for trust, designed for ease
Employees often store credentials in apps, spreadsheets, or even on paper. Smart Scanner makes it fast and easy to migrate those credentials into an encrypted vault.
Reduced IT burden
By simplifying credential management, you can reduce password reset requests. Smart Scanner makes secure behavior the easiest behavior, so your IT team can focus on mission-critical tasks.
Stronger Zero Trust foundation
In a Zero Trust approach, visibility is everything. Smart Scanner ensures every login is captured and secured.
Built for how people actually work
Smart Scanner was designed to meet users where they are, whether that’s handwritten notes or printed documents.
Whether you’re new to LastPass or finally bringing every password into one place, Mobile Smart Scanner helps you spend less time setting up and more time enjoying secure access to your digital life.
Simplify security without compromise
Mobile Smart Scanner is now currently available to all customers, including business users.
This means your business will be able to equip teams with a faster, more intuitive way to adopt secure access from day one.
So, go ahead. Scan. Save. Secure. Mobile Smart Scanner removes one of the last barriers to secure access, so every credential is protected from the very start.
