Mobile
LastPass for Windows Phone 7 Has Arrived!
Amber SteelPublishedDecember 29, 2010
LastPass is now available for download in the Windows Phone 7 marketplace!
Once installed, the app allows you to view your vault and search for your saved sites:
After logging in to your account, a small menu appears at the bottom of the screen, allowing you to select "launch mode", in which tapping a site launches it in the embedded browser, or "details mode", in which tapping a site allows you to view the data saved in the site entry.
There are some known limitations with the app; autofill will only work on sites that use javascript, an issue which we hope Microsoft will address. The app is also currently read-only, which means you can't add or change site data, although we will adjust this for future releases.
Thank you for your patience as we resolved issues and pushed forward through the approval process!
