- Chrome's extension support is only available in their dev builds, so you must first install the dev channel of Chrome.
- Then, to install LastPass, point Chrome to: https://lastpass.com/lpchrome.crx
- Finally, it is recommended that you disable the built-in password manager by clicking on the Options (under the customize and control 'wrench' button). Then choose the 'Personal Stuff' tab and select 'Never save passwords' and 'Never save text from forms'.
LastPass for Google Chrome Alpha has begun, we've had a good review despite it's very early status: http://www.downloadsquad.com/2009/09/30/lastpass-extension-for-google-chrome-now-available-and-it-rocks/
3 steps to install:
