- The network perimeter is officially dead. In 2026, attackers are targeting identities, with 40,000 token theft incidents occurring every single day.
- SSO and federated identity management (FIM) aren’t the same thing. The first manages access within a single organization, while the second extends authenticated trust across multiple organizations.
- A FIM solution that enables SSO and minimizes login friction can lead to 24% happier employees and 26% higher productivity.
- The ShinyHunters gang didn’t have to break an OAuth or SAML protocol to compromise Panera Bread or Tinder. They simply called employees on the phone and tricked them into entering credentials on fake portals, which is why FIM alone will never be enough.
- Who’s afraid of spoofing? With LastPass domain-bound autofill, IF the domain doesn’t match credentials, LastPass won’t autofill.
- Vishing calls are no match for FIDO2 hardware security keys. And it’s available to LastPass Business Max customers, making it the sharpest dividing line between businesses that are protected and those that only think they are.
It's 2026: Do you know where your identities live? Every new vendor you onboard, and every SaaS tool your team adopts leads to sprawl, exactly what federated identity management (FIM) and SSO are built to eliminate.
Right now, identity is the new perimeter – and the experts have plenty to say about it.
They predict that 70% of breaches will stem from the compromise of identities, with AI agents automating every step of an attack. Alex Cox, TIME and AI transformation director at LastPass elaborates:
"Defenders will likely see threat actors use agentic AI in an automated fashion as part of intrusion activities, continue AI-driven phishing campaigns, and continue development of advanced AI-enabled malware."
Yet, organizations are rushing to adopt hybrid cloud, with the adoption rate projected to hit 90% by 2027, a shift that creates expanded access vectors through SaaS apps, third party vendors, and stolen credentials.
The upshot? Access management has become the defining security challenge of our time. This is exactly why FIM is having its moment in the spotlight.
Below, we explain exactly what FIM is, how it compares to SSO, and how to implement it effectively in 2026.
What Is Federated Identity Management (FIM) and why does it matter more than ever?
Federated identity management (FIM) lets you access resources across multiple organizations and platforms using a single set of credentials.
Essentially, FIM uses SSO for multiple system access.
What are the key components of federated identity management (FIM)?
Federated identity management relies on a mutual trust arrangement between two parties: identity providers (IdP) and service providers (SP). The key components of FIM include IdPs, SPs, and SSO.
We'll explain more below. Right now, we'll answer a key question we're often asked: What's an example of a federated identity?
Think of the last time you signed up for an online service.
If you were given the option of signing in with Google, Facebook, or LinkedIn, that's an example of federated identity. Instead of creating a new set of credentials, you logged in with your Facebook credentials.
So, Facebook authenticated your identity, and you received access to the service you signed up for.
Essentially, Facebook and the service platform have a mutual trust agreement. In an enterprise context, the same principle applies at scale. Your company's identity provider authenticates your employees once, and every app or partner platform in your federation trusts that authentication.
The result is seamless, secure access, without the sprawl of duplicate credentials.
The key components of FIM are:
- Identity provider (IdP): This is the central authority that verifies user identities and issues tokens.
- Service provider (SP): This is the service or platform that honors the tokens provided by the IdP and grants access.
- Authentication & authorization protocols: FIM relies on a set of protocols to communicate trust between IdPs and SPs. SAML 2.0 uses XML-based assertions to authenticate users and is a popular choice for enterprise SSO. It easily authenticates your employees to internal and SaaS apps using just one corporate identity. Another option is to use OAuth 2.0 with OpenID Connect (OIDC). OIDC issues an ID token (JWT) for authentication, alongside OAuth 2.0 access tokens for authorization. OAuth 2.0 & OIDC are increasingly the modern standard for securing API calls and web & mobile apps.
- Single sign-on (SSO): This allows users to log in once to access multiple resources. SSO and FIDO2 passwordless authentication are two complementary technologies that support FIM.
- Cross-domain access: Organizations can collaborate closely, enabling seamless access to each other's resources.
- User convenience and security: FIM reduces the need for multiple logins, preventing password reuse and the likelihood of threat actors gaining unauthorized credential access.
- Mutual trust agreements between IdPs and SPs: IdPs authenticate users for SPs that control access to requested resources.
How can federated identity management help your business?
A FIM solution that enables Single Sign-On (SSO) and minimizes login prompts dramatically reduces workplace friction.
Research from HappySignalsshows that human‑centric, low‑friction IT systems lead to 24% happier employees and 26% higher productivity.
Login friction is one of the most fixable causes of employee dissatisfaction, and employers are taking note. The global market for SSO is projected to reach US$8.4 Billion by 2030.
Perhaps one of the greatest benefits of FIM lies in its cost savings. By consolidating identity management into a single framework, FIM reduces the costs of managing multiple IAM systems.
Finally, FIM makes it easy to generate robust reports on who accessed what, when, and from where.
These reports directly support identity governance and help demonstrate compliance with data protection standards like GDPR, HIPAA, and SOC 2.
How Does Federated Identity Management (FIM) work?
Authentication and authorization process
- In an FIM system, a user must go through an authentication and authorization process to access resources:
- First, the user attempts to log in to an application or portal managed by the service provider (SP).
- The SP redirects the user to a trusted identity provider (IdP).
- The IdP presents an authentication page to the user.
- Next, the user verifies their identity via biometrics, MFA, FIDO2 hardware keys, or a combination.
- The IdP then verifies the user against its user directory (Microsoft Entra ID, for example).
- Upon successful authentication, the IdP creates an assertion (SAML assertion or OAuth token) and sends it to the SP.
- The SP validates the assertion, extracts user identity data (such as roles and permissions), and evaluates it against its access control policies.
- Finally, the SP grants or denies access to resources based on its evaluation.
Where is FIM actually used?
FIM is used across enterprise IT environments, cloud platforms, and cross-organizational collaboration.
Enterprise environments
This is the most common deployment for FIM.
Integrating FIM into an enterprise environmentinvolves:
- Identifying the applications and services that will participate in the identity management ecosystem
- Choosing an established federated identity provider (IdP)
- Choosing and implementing the right FIM protocols
- Configuring the IdP to authenticate users for the SP
- Ensuring security measures like 2FA/MFA are in place
- Testing to ensure that SSO works as expected and the federated identity infrastructure is secure
- Training staff on using the federated identity management system
Cloud computing
Cloud computing is where FIM's value accelerates. As businesses migrate to hybrid clouds, identity management becomes more complex.
FIM allows cloud services to authenticate using the organization's chosen IdP.
In Google Cloud, for example, you can configure Google Workspace to accept authentications from an IdP such as Microsoft Entra ID or Active Directory Federation Services (ADFS).
Cross-domain collaborations
Cross-domain collaborations are perhaps the most powerful use case for FIM.
One example is a collaboration between researchers studying food insecurity on different continents.
FIM allows them to collaborate on a joint research project across a shared platform like ORCID.
With federated SSO (single sign-on) on ORCID, researchers can use their institutional credentials to access all documents, databases, and research materials relating to their project.
Another example is a car manufacturer allowing parts suppliers from anywhere in the world to access its inventory portal.
Federated SSO allows these suppliers to collaborate with the car manufacturer across the automotive supply chain.
In each case, FIM creates a trust framework that secures operations across corporate boundaries, a capability that has moved from nice-to-have to mission critical as our world becomes more interconnected.
Federated identity management vs SSO: What's the difference?
The fundamental difference between SSO and federation is scope.
Although many people use the terms interchangeably, there's a difference.
SSO manages access within a single organization, while FIM extends that authenticated trust across multiple organizations.
When evaluating federated identity vs SSO, the deciding factor is almost always whether your access needs cross an organizational boundary.
What are your SSO options? A quick reference
Understanding the difference between federation vs SSO also means understanding that SSO comes in different forms.
- Enterprise SSO is the classic internal model. This is where one login unlocks all apps within a single organization. It's ideal for managing employee access to internal tools.
- Federated SSO extends authentication trust beyond a single organization. When your employee logs into a partner portal using your company credentials, that's federated SSO. It's the version of SSO that powers FIM.
- Social SSO is what you as a consumer experience. It's signing in to a service using Google, Apple, LinkedIn, or Facebook. It uses the same federated trust model in a consumer context.
How do I choose between SSO and FIM?
Choosing between SSO and FIM will depend on several factors.
SSO is the right choice when:
- Your access management needs are primarily internal.
- You want a faster, lower-cost implementation.
- You're managing one organization's app portfolio without significant third-party integrations.
FIM is the right choice when:
- Your business collaborates with multiple suppliers and partners across geographic boundaries.
- You have multiple IdPs and SPs to manage.
- You need robust auditing and reporting across domains to meet global compliance standards.
- You're operating in a hybrid cloud environment with external-facing services.
SSO vs FIM: Quick guide for small businesses
| SSO | FIM | |
| Best for | Employees accessing your internal tools | Employees and contractors accessing partner systems or cloud services |
| Login experience | One login unlocks all your apps for employees | One login works across your company and trusted partners |
| Setup ease | Simple if using IdPs like Okta or Entra ID | More setup for trust agreements between organizations |
| Cost/security | Central control + MFA enforcement | Home IdP handles MFA once, with attributes shared securely across firms |
| Example | Your staff uses one login to access payroll, HR, SaaS apps | Consultant from Agency X completes MFA at their agency IdP, then accesses your CRM |
LastPass Business Max supports both SSO and FIM – including federated logins via ADFS and Entra ID. See how Business Max cansupport your team.
Is Federated Identity Management (FIM) worth it? Benefits, challenges, and what to look for
The advantages are substantial
Here are four ways FIM can benefit your business:
- Scalability: Your business can scale identity access management as it grows without significant infrastructure changes.
- Operational efficiency: Your IT team can focus on higher order tasks because they no longer need to manage credentials for each application separately.
- Improved workplace morale: With FIM, you can enforce strong password and account lockout policieswithout overwhelming your employees.
- Enhanced security: FIM's centralized authentication and authorization process contributes to a more positive security posture for your business.
The challenges are real
Despite its benefits, there exist several challenges in FIM:
- Privacy concerns: For FIM to work, user identities must be shared with third parties. How and what information is shared will impact the safety and privacy of your employees.
- IdP dependence: Depending on a single IdP can create a single point of failure. If the IdP experiences an outage, all services relying on it will be affected.
- Integration complexity: Integrating FIM into an existing infrastructure can be challenging due to the need to ensure compatibility across all elements of the infrastructure.
What are the best practices for a successful FIM deployment?
The best practices for a successful FIM implementation are:
- Establishing clear protocols and access management guidelines to manage relationships between IdPs and SPs
- Ensuring interoperability by choosing widely adopted protocols such as OpenID Connect (OIDC)
- Implementing robust encryption and authentication mechanisms to protect sensitive user data such as PII. Look for an IdP with minimal data sharing practices.
- Removing abandoned or orphaned accounts
- Providing employee training to raise awareness about potential security risks
- Regularly assessing the integrity of your FIM system by gathering user feedback
- Implementing solutions that can adapt to evolving security threats
How secure is federated identity management, and what are the known risks?
FIM is highly secure when properly configured, but it introduces specific vulnerabilities, particularly around token theft and session management, which require targeted controls.
Core security measures to layer onto FIM
Some top security measures to consider in implementing FIM include:
- MFA as a baseline requirement: Every authentication event should require a second factor. This is non-negotiable in 2026 given the sophistication of credential attacks.
- AI-driven anomaly detection: Leverage to detect anomalies in real-time.
- Role-based and JIT (just-in-time) access: Rather than granting standing privileges, implement JIT accessfor specific tasks and revoke them immediately after.
- Identity-first security posture: Leading security experts now recommend treating identity, not the network, as the primary security perimeter, with SSO and federation as foundational controls.
Known vulnerabilities to defend against
#1 Token theft via AiTM (adversary-in-the-middle) attacks
This is now the dominant threat vector in federated environments, with attackers stealing tokens via PhaaS (phishing-as-a-service) kits, browser compromise, or supply chain attacks..
The problem with OAuth and session tokens is that they function as bearer credentials. They are like keys, which anyone can use once they have them.
And worse, token theft allows attackers to bypass traditional text-based MFA.
The scale of the problem in 2026 is significant. AiTM attacks have increased 146%, with nearly 40,000 incidents detected daily across Microsoft environments.
Real-world attacks are becoming more sophisticated.
- In February 2026, Bleeping Computer reported on the combined use of voice phishing (vishing) and device code phishing to steal tokens.
- The attacks were linked to the ShinyHunters extortion group.
- In the vishing attacks, the attackers impersonated IT support staff, called employees, and tricked them into entering their credentials and MFA codes on fake corporate login portals. This gave them access to employee SSO accounts and all connected apps and services.
- In the device code phishing attacks, the ShinyHunters group abused the OAuth 2.0 Device Authorization Grant flow to obtain authentication tokens for employee Entra ID accounts.
The tokens allowed the attackers to access SSO-connected SaaS platforms like Microsoft 365, Salesforce, Google Workspace, Atlassian, and Slack, all without the attacker ever completing MFA.
The real-world damage in 2026 is significant: Confirmed ShinyHunters victims include Canva, HubSpot, Panera Bread, The Match Group (yes, the same one that runs Tinder, Match, and OkCupid), Epic Games, Moderna, Halliburton, and GameStop.
ShinyHunters claimed that it stole 10 million records from Match and 14 million from Panera Bread – a staggering theft of PII, not to mention the stigma of exposed dating profiles.
Sources: Malwarebytes,Security Week (2026)
The recommended countermeasures for token theft include:
- Enforcing Conditional Access policies
- Implementing Token Protectionwith device-bound credentials
- Implementing compliant network checks through Global Secure Access
- Short session lifetimes
- Behavioral monitoring for IP deviation and geographic anomalies
#2 Long-lived sessions
FIM systems often maintain extended sessions for convenience. But the longer a session lives, the wider the window for exploitation.
#3 Insider threats
FIM's centralized authentication doesn't protect against a legitimate user who's negligent or harbors ill intentions. Behavioral monitoring and least privilege access complements FIM for this threat vector.
In 2026, protecting your federated identity environment also means thinking beyond human identities.
Machine identities – service accounts, API keys, workload identities, and AI agents – now vastly outnumber employees20:1 or more.
And most operate without visibility or governance.
An effective FIM strategy must manage these machine identities with the same rigor applied to human identities.
Does LastPass Business Max support FIM?
Yes, LastPass Business Max supports FIM via SAML-based SSO, integrating directly with major IdPs like Entra ID, Okta, and Active Directory Federation Services (ADFS).
This means your employees can use their existing IdP credentials to access LastPass; no separate master password required.
And here's another consideration: LastPass hardens the human layer that attackers are increasingly targeting.
The ShinyHunters campaign made one thing painfully clear: You don't need to crack SAML or OAuth protocols to defeat federated security.
You just need to trick employees into handing over their credentials.
Business Max addresses that gap in two ways:
- LastPass autofillonly enters credentials on the exact domain they were saved for. So, even if your employees land on a phishing site, LastPass simply won't enter their credentials. This means your employees don't have to be perfect in recognizing a phishing portal. Business Max keeps them safe, and here's why this matters: In a federated environment, a compromised SSO credential doesn't just unlock one app; it unlocks everything connected to it. Autofill is one of the simplest controls you can put in place to protect your employees and business.
- LastPass Business Max includes support for FIDO2 hardware security keys like YubiKey, which is recommended by CISA as the gold standard for phishing resistant authentication.
A vishing callercan trick your employee into entering their credentials. But they can't physically insert a hardware security key into your employee's device to authenticate a login that wasn't initiated by your employee. LastPass protects the human identity layer and is a critical complement to your FIM architecture.
To try Business Max for yourself, unlock your 14-day free trial now (no card required).
See why 100,000+ businesses trust LastPass to secure their human identities.
Have questions about how LastPass integrates with your existing IdP? Contact our team for a personalized walkthrough.
Sources
Solutions Review: Identity security predictions from industry experts for 2026 and beyond
Tech News World: AI dominates cybersecurity predictions for 2026
Command Line Ninja. Single Sign-On (SSO): SAML vs OAuth vs OIDC - What's the difference
Ping Identity.Single sign-on vs. federated identity management: The Complete guide
Security Boulevard: Machine identity was the focus at Gartner’s IAM Summit
Aembit: Why fragmented machine IAM is failing
Obsidian Security. Token-based attacks: How attackers bypass MFA (2026)
Bleeping Computer: Hackers target Microsoft Entra accounts in device code vishing attacks (2026)
Bleeping Computer: ShinyHunters claim hacks of Okta, Microsoft SSO accounts for data theft (2026)
