6 Best Password Managers for iPhone and iPad in 2026
LastPass • PublishedNovember 04, 2025
Your iPhone already does a lot to keep you secure, but managing passwords across all your apps and websites takes more than what's built in. A dedicated iPhone password manager gives you stronger passwords, faster logins, and the peace of mind that comes from knowing your accounts are protected.
This guide covers the best password manager apps for iPhone and iPad. You'll find options that work right inside Safari and your favorite apps, with Face ID and Touch ID support for instant access. LastPass stands out for its smooth iOS integration and the multiple ways it lets you recover your account if you ever forget your master password.
Quick guide: 6 best password managers for iPhone and iPad
  • LastPass: The best overall iPhone password manager according to G2 global grid reports
  • Bitwarden: Open-source with regular third-party security audits
  • 1Password: Customizable home screen for quick access to favorites
  • Dashlane: Biometric recovery resets your master password with Face ID
  • NordPass: OCR scanner captures credit cards using your iPhone camera
  • Keeper: Offline mode keeps your passwords available without internet
How we evaluated the best password managers for iPhone
We evaluated these password managers based on how well they work on iPhone and iPad. Your password manager should feel like a natural part of iOS, filling your passwords the moment you tap on a login field. Here's what we looked for:
  • iOS integration: Does it work with Safari autofill and Face ID or Touch ID?
  • Ease of use: Does the app fill your passwords without extra steps?
  • Cross-device sync: Do passwords sync between your iPhone, iPad, and other devices?
  • Offline access: Can you view your passwords without an internet connection?
  • Recovery options: What happens if you forget your master password?
  • Security features: Does it alert you to weak or compromised passwords?
The 6 best password managers for iPhone and iPad
1. LastPass: Best overall iPhone password manager
LastPass works with iOS Password autofill, which means your passwords appear right in Safari and any app with a login screen. When you tap a password field, LastPass pops up with your saved credentials. One tap fills everything in, and Face ID or Touch ID unlocks your vault instantly.
Getting started takes just a few minutes. Install the app, enable autofill in your iPhone settings, and LastPass handles the rest. As you log into websites and apps, LastPass can save your passwords automatically. You don't need to manually add each one.
If you ever forget your master password, LastPass gives you multiple ways to recover your account. You can use Face ID recovery, a one-time recovery password, or get help from your account admin if you're on a business plan.
LastPass features
  • iOS Password autofill: Your passwords appear directly in Safari and apps without opening the LastPass app
  • Face ID and Touch ID: Unlock your vault with biometrics instead of typing your master password
  • Password generator: Create strong, unique passwords for every account with one tap
  • Security Dashboard: See which passwords are weak, reused, or found in data breaches
  • Dark web monitoring: Get alerts if your email or passwords appear in known breaches
  • Multiple recovery options: Recover your account through Face ID, one-time passwords, or admin assistance
LastPass pros and cons
Pros:
  • "Works seamlessly with all extensions on every browser. Easy to manage shared passwords across groups, and very simple to share and retract access to passwords." –verified review
  • "The best part is having it everywhere: my phone, my tablets, my desktop, my laptop. I'm never without a necessary password." –verified review
  • "The syncing of passwords across devices makes it so easy to use when on the go!" –verified review
Cons:
  • "Nothing to dislike! If they had a VPN service that would be amazing!" –verified review
  • "I wish I could share the same password with multiple groups instead of one." –verified review
2. Bitwarden: Open-source with regular third-party security audits
Bitwarden publishes its code publicly, which means security researchers can examine exactly how it protects your passwords. Independent firms like Cure53 conduct regular security audits and publish the results, so you can verify the app does what it claims.
The iOS app supports Face ID and Touch ID for quick vault access. You can also use Bitwarden to generate two-factor authentication codes, which eliminates the need for a separate authenticator app on your iPhone.
Bitwarden features
  • Open-source code: Security researchers can examine and audit the code that protects your passwords
  • Built-in authenticator: Generates two-factor codes directly in the app instead of requiring a separate authenticator
  • Face ID and Touch ID: Unlocks your vault with biometrics on compatible iPhone and iPad models
(Platform features reflect the information available on the Bitwarden website as of the publication date.)
Bitwarden pros and cons
Pros:
  • "With all the attacks there are, being able to verify if your password has been stolen is what I like the most." –verified review
  • "I like the ability to sort passwords by folder, making them easy to find and use." –verified review
  • "I appreciate Bitwarden's robust security features, ease of use across devices, and the ability to securely share passwords with others." –verified review
Cons:
  • "Sometimes the autofill feature can be inconsistent on some browsers." –verified review
  • "The occasional syncing delays between devices can be a bit inconvenient." –verified review
  • "The UI could be a bit more user-friendly. Other password managers might be a bit easier to use at times." –verified review
3. 1Password: Customizable home screen for quick access to favorites
1Password lets you customize your home screen with drag-and-drop sections. You can pin specific passwords, credit cards, or secure notes so they appear the moment you open the app. This saves time when you need to access the same accounts repeatedly throughout the day.
The app supports Face ID and Touch ID for unlocking your vault. Note that 1Password requires a Secret Key in addition to your master password when setting up new devices, which adds security but also means you'll need to keep that key somewhere safe.
1Password features
  • Customizable home screen: Lets you pin your most-used items and organize sections with drag-and-drop for faster access
  • Face ID and Touch ID: Unlocks your vault with biometrics on iPhone and iPad
  • Passkey support: Stores and uses passkeys for passwordless login on sites that support them
(Platform features reflect the information available on the 1Password website as of the publication date.)
1Password pros and cons
Pros:
  • "Helps users securely store and manage passwords, financial details, documents, and other sensitive information." –verified review
  • "It's very convenient to log into so many different apps and services with just one password." –verified review
  • "Great security, excellent features and capabilities and intuitive and clean user friendly interface." –verified review
Cons:
  • "The autofill feature doesn't work smoothly across all websites or browsers." –verified review
  • "Synching vaults between new versions of 1Password can create duplicates." –verified review
  • "Multiple apps (browser, pop up app, desktop app) can be a bit confusing sometimes" –verified review
4. Dashlane: Biometric recovery resets your master password with Face ID
Dashlane offers biometric recovery, which means you can reset a forgotten master password using Face ID or Touch ID on your iPhone. If you've enabled this feature and forget your master password, you won't lose access to all your saved credentials.
The app syncs across all your devices, and you can view your passwords offline once you've logged in. This is helpful when you're traveling or in an area with poor cell service.
Dashlane features
  • Biometric recovery: Resets your master password using Face ID or Touch ID if you forget it
  • Offline access: Lets you view your saved passwords even without an internet connection
  • Automatic sync: Changes you make on one device appear on all your connected devices immediately
Dashlane pros and cons
Pros:
  • "The Password Health monitoring is nice. It makes it easy to see which passwords need improvement and make those updates." –verified review
  • "Web extension automatically fills login forms and logs in - when correctly configured, it's like those websites don't even require credentials anymore." –verified review
  • "It stores everything in the vault, so you don't need to do the admin work of creating and saving the credentials." – verified review
Cons:
  • "The mobile app is glitchy, and often doesn't stay logged in." –verified review
  • "I dislike logging into Dashlane every 14 days for it to work properly." –verified review
  • "You can't share a group of passwords, you can only share one at a time." –verified review
5. NordPass: OCR scanner captures credit cards using your iPhone camera
NordPass includes an OCR scanner that captures credit card information using your iPhone camera. Instead of typing in all 16 digits, the expiration date, and the cardholder name, the app reads the card and saves it to your vault.
The app supports Face ID and Touch ID for quick access. You can also view your passwords offline, though you'll need an internet connection to make any edits or add new items. Note that offline mode is read-only, so you can look up credentials but not create new ones until you're back online.
NordPass features
  • OCR card scanner: Reads credit cards and business cards using your iPhone camera
  • Offline viewing: Lets you access your saved passwords even without an internet connection
NordPass pros and cons
Pros:
  • "I appreciate the intuitive interface and ease of use." –verified review
  • "I like that all my passwords are stored in one place and that it's very secure." –verified review
  • "Usually pops up right away, making it super easy to log into websites" –verified review
Cons:
  • "Sometimes it has some bugs, I had to send an invite multiple times before it worked at first." –verified review
  • "I wish I could use NordPass on Safari as this is sometimes my primary browser." –verified review
  • "Sometimes the autofill function doesn't work (even though it's authorised)." –verified review
 6. Keeper: Offline mode keeps your passwords available without internet
Keeper stores an encrypted copy of your vault directly on your iPhone. When you're on a plane, in a basement, or anywhere without cell service, you can still open the app and access all your passwords. Any changes you make sync once you reconnect to the internet.
The app includes a built-in authenticator that generates two-factor codes, so you don't need a separate app for 2FA. Face ID and Touch ID let you unlock your vault without typing your master password each time.
Keeper features
  • Robust offline mode: Lets you access and use your passwords without an internet connection, with automatic sync when you reconnect
  • Built-in authenticator: Generates two-factor authentication codes directly in the app
Keeper pros and cons
Pros:
  • "Browser and app flexibility makes using the tool very easy to use." –verified review
  • "Keeper makes it easy and convenient to store strong passwords and utilize them across different devices." –verified review
  • "It integrates with all my devices and makes keeping passwords up to date very easy." –verified review
Cons:
  • "Autofill doesn't work with as many websites as some other competitor password managers." –verified review
  • "It logs me out of the web interface too much." –verified review
  • "Keeper Password Manager can be a lot to take in for new users." –verified review
Comparison table: Best password managers for iPhone and iPad
Platform
Free Plan
Free Trial
Recovery Options
LastPass
30days
Face ID, SMS, one-time password, admin reset,emergencyaccess
Bitwarden
None
Admin reset (business only),emergency access
1Password
14 days
Emergency Kit,Admin reset
Dashlane
14 days
Face ID, recovery key
NordPass
None
Keeper
30days
How do I set up a password manager on my iPhone?
Setting up a password manager on your iPhone takes just a few minutes. Download the app from the App Store, create your account with a strong master password, then enable iOS autofill in your settings. Go to Settings > Passwords > Password Options, and select your password manager as the autofill source.
Once enabled, your passwords will appear whenever you tap on a login field in Safari or any app. You can also enable Face ID or Touch ID in the password manager's settings so you don't have to type your master password every time you need to log in. Most password managers also offer a browser extension for Safari that gives you more control over saving and filling passwords.
Should I use iCloud Keychain or a third-party password manager?
iCloud Keychain saves passwords in Safari and syncs them across your Apple devices. But it's limited in a few important ways.
First, Keychain works natively only in Safari. You can use it in Chrome or other browsers, but you'll need to download and install additional software to make it work. A dedicated password manager works across all your browsers out of the box.
Second, Keychain doesn't tell you when your passwords are weak or reused. LastPass shows you a Security Dashboard with color-coded scores so you can spot problems before they become security risks. It also monitors the dark web and alerts you if your credentials appear in a breach.
Third, sharing passwords with Keychain is clunky. If you need to give a family member access to a streaming account, a dedicated password manager makes this simple and secure.
A third-party password manager becomes more useful when you need features Keychain doesn't offer. These include sharing passwords with family members, storing secure notes and documents, setting up emergency access, or syncing with Windows and Android devices. Third-party managers also give you more control over password organization and typically include security dashboards that show weak or reused passwords across all your accounts.
Why LastPass is the best iPhone password manager
LastPass stands out because it's designed for people who don't want to think about password management. Once you set it up, the app works quietly in the background, filling your passwords the moment you tap on a login field. You don't need to configure anything complicated or learn a new system.
The free plan gives you unlimited passwords on your iPhone or iPad. If you want to sync across all your devices, including your Mac and work computer, the Premium plan covers everything for a few dollars a month. Families can share a plan that gives everyone their own private vault plus shared folders for streaming accounts and Wi-Fi passwords.
Ready to protect your iPhone and iPad with better password security? Try LastPass for free and see how much easier managing passwords can be.
FAQs about password managers for iPhone and iPad
Password managers are one of the safest ways to protect your accounts. They encrypt your data so that only you can access it, and they generate strong, unique passwords for every account. This is much safer than reusing the same password everywhere or writing passwords down. Look for a password manager with zero-knowledge encryption, which means even the company can't see your passwords.
Yes, all major password managers support Face ID and Touch ID on iPhone and iPad. Once you enable biometric login in the app settings, you can unlock your vault with your face or fingerprint instead of typing your master password. This makes accessing your passwords quick and secure throughout the day.
iCloud Keychain handles basic password storage well if you only use Apple devices. A third-party password manager becomes more useful when you need to share passwords with family, store secure notes, access your vault on Windows or Android devices, or see detailed reports on weak and reused passwords. Third-party managers also offer emergency access features that Keychain lacks.
LastPass is the best iPhone password manager because it combines ease of use with features other password managers charge extra for. You get dark web monitoring, a Security Dashboard that flags weak passwords, and multiple ways to recover your account if you forget your master password. LastPass is also the leader in G2's global grid reports for password management.
LastPass offers a free plan that includes unlimited passwords on a single device, password generation, and secure autofill. The free plan gives you the core features you need to manage passwords securely. If you want additional features like dark web monitoring and emergency access, you can upgrade to a premium plan.
