7 best password managers for mobile (iPhone and Android) in 2025
LastPass • PublishedNovember 03, 2025
7 best password managers for mobile (iPhone & Android) in 2025
Your phone holds the keys to your digital life, from banking to social media, work accounts, and more. Managing all those passwords on a tiny screen can get frustrating, especially when you're rushing to log in at the grocery store checkout or trying to access an important document during your commute.
The right mobile password manager takes that stress away by creating and storing strong passwords for every account, then filling them with just a tap. LastPass stands out with easy-to-use apps that sync across all devices, so you never have to squint at your screen typing complex passwords.
Our guide covers the top password managers that work best on phones and tablets. You'll discover which apps sync passwords automatically between devices, give you access even without internet connection, and offer features like smartwatch support.
Quick guide: 7 best password managers for moble
LastPass: Is the best overall password manager, according to G2 global grid reports, and offers an accompanying mobile app
  • Dashlane: Works on smartwatches
  • NordPass: OCR scanner for cards
  • Keeper: Offline mode for travel
  • Bitwarden: Open-source transparency
  • RoboForm: Password recovery through biometrics
  • 1Password: Passkey support
How we evaluated the best mobile password managers
We looked at how well each password manager handles the specific challenges of mobile use. A great mobile password manager needs to work fast when you're unlocking your phone, fill passwords accurately in apps (not just browsers), and sync changes between devices without delays. We also checked whether each app lets you access passwords offline and includes mobile-specific features that desktop versions don't always have:
  • Biometric authentication: Can you unlock your vault with Face ID, Touch ID, or fingerprint?
  • Cross-device syncing: Do passwords update automatically between phone and computer?
  • Offline access: Can you view passwords without an internet connection?
  • Mobile-specific features: Does the app include smartwatch support, or passkey compatibility?
  • App autofill reliability: Does autofill work reliably across all your mobile apps?
  • Emergency recovery options: Can you recover access if you get locked out on your phone?
The 7 best password managers for mobile
1. LastPass: Best overall mobile password manager
LastPass opens with your face or fingerprint through passwordless biometric authentication on both iPhones and Android devices. This means you can skip typing your master password each time you need to access your vault. Because LastPass syncs your passwords instantly across all your devices, when you save a password on your phone, it's ready to use when you open your laptop.
If you’re an iPhone user, the iOS Password AutoFill integration means your passwords appear in Safari and all your apps without having to open LastPass first. On Android, helpful popup notifications appear above password fields for one-tap filling. You can also create and use mobile passkeys on sites like Amazon and Google directly from your phone.
LastPass features
  •    Passwordless biometric login and recovery: Opens your vault using Face ID, Touch ID, or Android fingerprint. Reset forgotten passwords through Face ID or fingerprint authentication.
  •    iOS autofill: Works directly with Safari and iOS apps
  •    Android autofill: Shows popup notifications for one-tap filling across all apps
  •    Dark mode support: Automatically matches your phone's system settings for better viewing
  •    Mobile passkey support: Works with Amazon, Google, and major sites directly from mobile
  •    Instant cross-platform sync: Passwords saved on mobile sync across Windows, Mac, and Linux immediately
  •    Offline access: View passwords (read-only) without an internet connection
LastPass pros and cons
Pros:
"I like logging in with biometrics and the ease of logging into websites directly from the app on my phone" – verified review
"The SSO integration provides security and peace of mind and makes it simple for users to use without the need to remember long complex master passwords." – verified review
"The best thing I find about LastPass is the cross-platform integration and ease of use on all platforms." – verified review
Cons:
"Sometimes it's not easy to get passwords stored into LastPass, though I have found that they have made improvements." – verified review
"Sometimes it is slow to pull up the vault." – verified review
"Some of the advanced features are only available with the premium plan." – verified review
2. Dashlane: Works on smartwatches
Dashlane brings full functionality to WearOS smartwatches, letting you authenticate directly from your Android smartwatch using passkeys. On mobile devices, biometric authentication (Face ID and Touch ID on iOS, fingerprint on Android) allows quick access without typing.
The offline access capability means your passwords stay available even if you lose signal. As long as you're logged in on your mobile device, you can view and use saved passwords as normal.
Dashlane features
  •    WearOS smartwatch support: Authenticate directly from Android smartwatches with passkey support
  •    Biometric recovery: Reset forgotten passwords through Face ID or fingerprint authentication
  •    Offline mobile access: View and use passwords without internet once logged in
 (Platform features reflect the information available on the Dashlane website as of the publication date.)
Dashlane pros and cons
Pros:
"Securing master access with biometrics is a nice touch." – verified review
"Clean interface, works with all browsers, great phone application." – verified review
"I like that Dashlane recognizes what website you're on and suggests passwords based on that data." – verified review
Cons:
"Sometimes the auto-fill is inconsistent, and I have to manually copy and paste my passwords or information." – verified review
"The autofill for fields can be a bit aggressive, and Chrome on Android doesn't work well with it." – verified review
"The built-in VPN feature isn't as reliable as other separated services." – verified review
3. NordPass: OCR scanner for cards
NordPass includes an OCR scanner to save credit and business cards using your phone camera (but doesn’t do the same for passwords). This editable digital text auto-fills into your vault, so you won't need to type long card numbers on your phone keyboard.
Biometric authentication gives you instant vault access through Face ID, Touch ID, or Android fingerprint sensors. Your passwords stay available offline too, though you'll need an internet connection to edit or add new items.
NordPass features
  •    OCR scanning technology: Saves credit cards, business cards, and handwritten notes with your phone camera
  •    Read-only offline mode: Access passwords without internet (editing requires connection)
  •    Cross-platform sync: Updates across Windows, macOS, Linux, Android, and iOS
(Platform features reflect the information available on the NordPass website as of the publication date.)
NordPass pros and cons
Pros:
"The autofill, cross-device sync, and clean interface make it fast and convenient." – verified review
"I appreciate the zero-knowledge architecture that ensures my data stays private." – verified review
"It supports things like biometric login, which makes logging in quick but still safe." – verified review
Cons:
"The mobile app, though functional, feels slightly less streamlined compared to the desktop version." – verified review
"The mobile experience occasionally lags behind the desktop version in terms of responsiveness and feature parity." – verified review
"Offline access is limited to the desktop app." – verified review
4. Keeper: Offline mode for travel
Keeper creates an encrypted copy of your vault stored locally on your mobile, so you have full access to passwords offline even without a phone signal (useful for international travel or remote work).
The native biometric login support covers Face ID and Touch ID on iOS, and fingerprint recognition on Android. WearOS smartwatch users can also access their most-used logins and two-factor authentication on their wrist.
Keeper features
  •    Offline mode: Encrypted local vault copy accessible without internet
  •    WearOS smartwatch app: Rotating carousel view with TOTP codes on your wrist
  •    Native biometric support: Face ID, Touch ID, fingerprint, and Windows Hello integration
(Platform features reflect the information available on the Keeper website as of the publication date.)
Keeper pros and cons
Pros:
"I appreciate Keeper for being reliable & having important features like being able to save passkeys to the record." – verified review
"Easy to use on desktop and mobile. Able to organize my folders and passwords and super easy to share them with others and set permissions." – verified review
"Website integration is good. Overall password grading and assistance are very helpful." – verified review
Cons:
"Syncing between devices occasionally takes a bit of time, and the mobile app could be slightly more responsive." – verified review
"Logging into multiple accounts on a mobile device can be frustrating at times." – verified review
"The mobile app is always saying "storage limit reached" even though we don't use Keeper for storing anything other than passwords." – verified review
5. Bitwarden: Open-source transparency
Bitwarden's mobile apps are made with Swift (iOS) and Kotlin (Android) for a responsive mobile experience. Because it’s open-sourced, anyone can verify the code.
The free tier includes unlimited passwords on unlimited devices with automatic sync across them.
Bitwarden features
  •    Native mobile architecture: Built in Swift for iOS and Kotlin for Android
  •    Passkey support: Create, store, and sync passkeys across mobile and browsers
  •    Open-source design: Built with public codebase
(Platform features reflect the information available on the Bitwarden website as of the publication date.)
Bitwarden pros and cons
Pros:
"I can use it across my devices (e.g., laptop, desktop, and even on my mobile phone) without experiencing any inconvenience." – verified review
"I can run the Bitwarden App on my Android mobile, Linux and windows laptop, in my browsers and it is really easy." – verified review
"The browser extensions and mobile apps integrate smoothly, so I always have access." – verified review
Cons:
"The Android app does not scale properly to my phone." – verified review
"It doesn't automatically prompt me to enter the password in the password field of every website using the mobile app, whether it's an iPhone or Android." – verified review
"The mobile is not 100% functional, there are bugs and errors when trying to auto-complete something and it doesn't work, it ends up freezing and closing the app." – verified review
6. RoboForm: Password recovery through biometrics
RoboForm’s Master Password Restore function allows you to reset it using Face ID, Touch ID, or Android fingerprint without losing your data.
Smartwatch support extends to Android’s Wear OS, so you can access logins, identities, and credit cards from your wrist with voice search capability.
RoboForm features
  •    Master Password Restore: Reset forgotten password through biometric authentication
  •    Smartwatch apps: Android’s Wear OS
  •    Built-in TOTP authenticator: Generates two-factor codes without separate apps
(Platform features reflect the information available on the RoboForm website as of the publication date.)
RoboForm pros and cons
Pros:
"Wherever I'm creating/modifying a password it's automatically saved on my computers and mobile devices." – verified review
"The software is very simple and intuitive, and its integration into browsers, mobile devices, or PCs is made very easy." – verified review
"Tried their mobile version app, I have a Galaxy Note and it works wonders on the go." – verified review
Cons:
"I wish RoboForm for Business had enterprise SSO capabilities on the mobile app." – verified review
"Creating a new login identity is difficult on a mobile device." – verified review
"The Android mobile app is somewhat clunky and difficult to use." – verified review
7. 1Password: Passkey support
1Password handles passkeys for passwordless authentication across your mobile apps and websites. You can create, store, and use passkeys directly from your iPhone or Android device without needing separate authentication apps.
The mobile app lets you reorder sections in the sidebar to organize your vault the way you want.
1Password features
  •    Customizable sidebar: Drag-and-drop sections with pinnable fields
  •    Watchtower monitoring: Real-time breach alerts with security scoring
  •    Native passkey support: Passwordless authentication
(Platform features reflect the information available on the 1Password website as of the publication date.)
1Password pros and cons
Pros:
"Seamless sync across desktop, mobile, and browser." – verified review
"The mobile app is especially reliable. I’ve never had any issues." – verified review
"Web browser extensions and desktop/mobile apps make it easy to leverage through current workflows." – verified review
Cons:
"FaceID doesn't always work on the mobile app." – verified review
"The interface can feel a bit overwhelming at first, especially for new users unfamiliar with password managers." – verified review
"While autofill generally works well, some legacy or custom login forms are not recognized, requiring manual copying and pasting." – verified review
Comparison table: The best mobile password managers
Platform
Biometric Authenticator
Offline Access
Smartwatch Support (full vault or TOTP (Time based One-Time Password)
LastPass
Face ID, Touch ID, Fingerprint
Read-only
Apple Watch
Dashlane
WearOS
NordPass
Read-only
Keeper
Apple Watch, WearOS
Bitwarden
Read-only
Apple Watch
RoboForm
Wear OS
1Password
Apple Watch
What features make a mobile password manager worth using?
A good mobile password manager autofills passwords directly in mobile apps, not just browsers. Biometric authentication also matters, since it’s most convenient to open your vault with Face ID or fingerprint instead of typing on that small keyboard.
A password manager with automatic cross-device syncing keeps your passwords up to date no matter which device you're using: If you save a new password on your phone during lunch, you'll also want it available on your work computer. If your password manager offers offline access, you won’t lose access to important passwords when traveling or in areas with poor signal.
Additionally, look for password recovery options, like resetting through biometric authentication, that help you regain access if you forget your master password. Some password managers let you designate trusted contacts, who can request access to your vault after a waiting period. This comes in handy if family members need access to important accounts in the event of an emergency.
How do mobile password managers keep my data safe?
Your mobile password manager uses strong encryption to protect your passwords, just like the desktop version does. The main difference is how you access your vault. Instead of typing your master password you use your fingerprint or face scan.
The company running the password manager can't actually see your passwords. Your master password unlocks everything locally on your device, and only the encrypted version syncs between your devices. LastPass uses this zero-knowledge approach, meaning your data stays private even from LastPass itself.
Mobile apps add some security advantages. Nobody can peek over your shoulder to see you type a password when you're using Face ID. Apps can lock themselves after a few minutes of inactivity. And even if your phone gets stolen, you can remotely wipe your password data before anyone accesses it.
Why LastPass is the best mobile password manager solution
LastPass keeps mobile password management simple with a user-friendly app you can start using right away. Open your vault with Face ID, Touch ID, or your fingerprint with no master password typing required. Your passwords appear right in Safari, Chrome, and all your apps without you having to switch back and forth.
You can create and use passkeys directly on sites like Amazon and Google from your mobile device. Everything syncs across your devices, so a password you save on your phone is ready when you need it on your laptop.
Ready to secure your mobile passwords the easy way? Try LastPass now and see how simple password management can be.
FAQs about mobile password managers
Your phone's built-in password manager shows some saved passwords in Settings, but a dedicated app like LastPass centralizes everything. Install LastPass, and it saves passwords as you log into apps and websites. You can then view all passwords in one secure vault accessible through biometric authentication.
LastPass offers the best mobile password manager. It’s easy to use even if you’ve never used a password manager before, giving you passwordless biometric authentication that works right away. The app syncs passwords across all devices and integrates with iOS Password AutoFill and Android Accessibility Service. LastPass makes mobile password management feel effortless while keeping your data secure with zero-knowledge encryption.
Password managers store your passwords in an encrypted vault in the app's secure storage area on your device. LastPass uses AES-256 bit encryption to protect this vault, which can only be unlocked with your master password or Face ID, Touch ID, or your fingerprint. The encrypted data syncs to the cloud for access across devices but remains unreadable without your credentials.
On iPhone, LastPass appears as an app on your home screen and integrates with iOS Password AutoFill. Go to Settings > Passwords > Password Options and select LastPass to enable system-wide autofill. Your passwords then appear directly in Safari and apps without opening the LastPass app separately.
Android users find LastPass as an app icon and can enable it through Settings > Passwords & accounts > Autofill service. LastPass uses Android's Accessibility Service to display password prompts above login fields. The app works across all browsers and apps, making your passwords available wherever you need them.
