What are password anxiety and fatigue?
If you've checked the news lately, you may have seen yet another story about a massive data breach. Or, you might have received an email from one of your service providers notifying you of a breach and advising you to change your password as soon as possible. You might understandably feel some password anxiety as a result. Figuring out how to address that anxiety, however, is where you can quickly get stuck. Manually keeping track of all of your passwords is way more difficult than it has to be — especially now that you're living more of your life online than ever before. That's where the password fatigue comes in. Without meaning to, you could fall into bad password habits. You might underestimate your risk, for example, by assuming you have fewer online accounts than you actually do. You might also believe that hackers aren't interested in your data. You might be concerned about forgetting your passwords, defaulting to the method that you feel will give you more control (like writing them down), even if you know that system isn't secure.5 tips for improving your password security
Although it's perfectly human to feel password anxiety and fatigue, there's only one way to rid yourself of them for good — by improving your password security. These five tips will help you do just that.- Don't reuse passwords. Using the same password for multiple accounts greatly increases your risk because if a hacker guesses or cracks that one password, they could use it to log into your other accounts. For this reason, it's best to use a unique password for each of your online accounts.
- Update your passwords. If you haven't updated your passwords in a while, it's a good idea to take care of that now. If any of your passwords are stolen in a data breach, they could end up on the dark web. From there, hackers might try logging into one or more of your personal or work accounts. By updating your passwords, you can shut the door on them before they get in.
- Use strong passwords. If a password is easy for you to remember, it's also easy for others to guess or crack. That's why it's important to use a strong, complex password for each of your online accounts. A strong password should have at least 16 characters including a mix of capital letters, lowercase letters, numbers, and symbols.
- Take advantage of MFA and biometrics. If any of your online accounts offer additional authentication options like multi-factor authentication (MFA) or biometrics, take advantage of them. Begin with your most frequently used accounts and move on from there, enabling these features when you find them.
- Monitor your data. It's important to know as soon as one of your accounts has been breached. Dark web monitoring services and credit monitoring tools can alert you when your information has been compromised so you can reset the affected password and understand how you may have been impacted.
